So, I just finished a World of Tanks game, the results screen loads, and my computer reboots itself, then gets to the "windows did not shut down properly, how would you like to load windows" screen at which point it just turns off.
I immediately unplug everything and open up the machine. I can smell what seems like heated plastic but not really anything burning. The CPU heat sink has a lot of dust build-up and is hot to the touch, but that isn't always necessarily uncommon.
I clear it and all the other fans out thinking it may have been an overheat issue and plug it back in and boot it back up. I then hear a loud "crack" sound and the machine doesn't boot at all (though it does power on) and I can smell a bit of burn-y-ness, and immediately unplug the machine and simply removed it.
At this point I'm thinking it's the power supply rather than any heating or CPU issue, but everything above is pretty much all I can tell you about what happened, does anyone think they can help confirm/deny or narrow down the issue any better?
Specs in sig.
Thanks in advance!
No Cross Posting, if you thing you'd get better results in a different category request a move.
AT MOd
Gillbot
Specs in sig.
Thanks in advance!
AT MOd
Gillbot
