hard drive wont work...maxtor d740x...too advanced for POS computer?
MrDudeMan
15,069
94
i got the maxtor d740x for my moms computer (p2 400 and i think the abit VH6 (or something like that) mobo)
it wont even post in that computer
it posts fine in my computer (p4, etc.)
what is the deal?
if i get a controller card, can it boot from the card?
EDIT
its a BH6 not a VH6
Viper96720
4,390
Maybe a bios upgrade is needed for the motherboard. So it can recognize the larger drive. Depending on if your mb is vh6 or vh6 ver 1.1. There's a bios that says support for 137gb drives or larger for both. But make sure to get the one for your board. Otherwise a pci ide card would work.
MrDudeMan
15,069
94
you guys are the best
ill brb with specific info on the board....maybe we can figure this out after all
MrDudeMan
15,069
94
here is the link to some of the new bios versions i found
think the newest one will fix this? it says a few lines down that this one is a "fix" for 40gb+ drives
woohoo think this may be the problem?
MrDudeMan
15,069
94
Originally posted by: ScrapSilicon
you have not answered my ? ..read here ..and gl :)
oh sorry
i had a 9gb drive in there and i am trying to replace it with a 40gb maxtor
not transfering anything, just a clean install
ScrapSilicon
13,625
oh sorry
the MaxBlast utility I linked to has EZBIOS ..I put an 80GB in a p2 233 machine with it ..mobo says its a 6 ..who cares what the mobo BIOS thinks as long as it runs and is all there..;)
MrDudeMan
15,069
94
cant get this to work..
when i click on the drive in the max blast setup
it says "invalid drive selection"
ScrapSilicon
13,625
did you acquire this drive used..? if so use Maxtor's PowerMax utility
zephyrprime
7,512
Try doing the bios flash like others here have said.
Check the master/slave settings on the drive.
Use ezbios if you have too.
If worse comes to worse, use the 32gb limiting jumper on the drive.
You'll probably get this drive going with a little effort. The drive obviously works and your mom's computer isn't that old. Good luck!
MrDudeMan
15,069
94
got it to work guys
its been so long since ive used such a POS computer that i forgot what was going on...
<-- is spoiled by the ease of windows xp
anyways, i updated the bios with award flash
thanks for all of the help everyone! i appreciate it
btw...i used the maxtor program you sent me to scrapsilicon but, like i said, the POS computer wouldnt even let that do its magic
RanDum72
4,330
Go to the BIOS first and make sure the drive parameters are not set manually for your older drive. Set everything to 'auto' so that the BIOS would automatically detect the new drive's settings.
