Hard Drive too big?
jcontonio
162
I am installing Win NT on my Maxtor 20 Gig....NT is saying that the drive is too big even though it only sees 8 Gigs of it...what's up? How do I remedy this?
jthsmak
732
If you are using fat16 that might be the prob. For a minute I thought your hard drive was too big so you were gonna send it to me. ;)
htown
80
I'm running two maxtor 20gbs with no problem.
Win2k is on one hard drive and Win98se is on another.
Cluster size is set to 16K and on a FAT32 file system.
Pariah
7,357
20
That was pretty good digobick, it was wrong for about 30 seconds and you caught it.
MrBond
9,911
Does your bios support drives larger then 8gb? That could be the problem. What board are you using?
Pariah
7,357
20
It's a Windows NT boot partition limitation. I think most 1.2GHZ Athlon systems have the 8GB IDE limit BIOS patch.
