Armageddon415
Is the sensor on the Diamondmax 9 series internal or external? Reason I ask is that I recently mounted a fan under the hd and I got a 10C temp drop. I'm wondering if its just because air is blowing over the sensor or if the internal temp really dropped that much. I'm using a SN41G2, the temp before I mounted the fan would range from 40-45C, now its down to 27-28C.
