- Jun 30, 2004
- 16,617
- 2,023
- 126
I learned way back in the 1980s -- don't use a magnetized screwdriver when installing or working with hard disks. I was never completely sure whether it would cause data loss, or permanent damage to the drive itself.
Here's what just happened to me.
I had a Seagate 7200.10 320GB which had originally been configured with Windows XP as a single drive -- for testing a system destined for 4-drive-RAID5. This original disk--- same model as the 4-drive-RAID -- was intended to be a "spare" or backup in case I had to hot-swap a drive from the RAID array.
I stored the drive temporarily in cardboard box -- even forgetting for a while that the drive was in that particular box.
Months later, I swapped out a CPU cooler from a different system with the Noctua-NH-U12P. The Noctua comes with a Noctua fan which elicited positive responses from our community, but I decided not to use it.
I set the fan on top of the box containing the drive, where it sat for several months.
Then today, I was assessing the relative weights (and merits) of two heatpipe coolers by using our kitchen scale to weigh cooler-fan combinations. I happened to weigh the Noctua fan, and noticed that it contained magnets when I tried to pull it off the metal (iron or steel) tray of the scale. I returned it to where it had been stored -- having forgotten what was in the cardboard box, and noticed the same "magnetic pull" when I attempted to lay it down on that box.
Who knows? Can I just repartition the drive and then reformat it? Or is the drive permanently a loss? I would think it would only have damaged the data, but I'm looking for second opinions here.
