unr3al
I'm using a Western Digital Caviar Green hard drive, 500GB; WD5000AADS-00L4B1
The problem I'm having, is that I suddenly have trouble getting the BIOS to recognize the drive. Detection takes an eternity and when it eventually succeeds the drive doesn't exist. Then I fiddle with the cables and voila it works like nothing was ever out of the ordinary. My 500GB Samsung drive has never had this trouble and I suspect spin up time might be at fault.
My motherboard is a Biostar TA770E with a 3GHz Athlon II 250 and 4GB Corsair XMS2 800MHz. I also have a Force3D ATi HD4850 1GB that draws all power from the PCI-express slot (no external power connector). Power supply is the so-called 470W Gigabyte Odin (400W continuous output, shame on you, Gigabyte). Power is no problem, I am running my GPU overclocked from 625MHz/900MHz to 680MHz/990MHz and CPU at 3.4GHz, with my memory just over 900MHz. Everything is stable and I haven't had any BSoDs during games or stress testing. No artefacts are visible in any game either, including RE5 that used to artefact my card left, right and center until I upped the PCI-e voltage from the board's default 75W to 125W.
Unfortunately, my WD drive is my primary boot drive, so every time I shut down (hard reboots doesn't have this effect, only complete shutdowns) I am stuck without a boot drive. I have struggled from 5 minutes to half an hour to get my PC to boot and the hard drive itself is completely healthy as well, according to SpeedFan's analysis of its S.M.A.R.T. data.
If someone has an idea on this, I would be quite glad... My PC is being transported 4 days a week and bootup now takes up to half an hour instead of half a minute, so you can understand if I'm a little frustrated!
