I'm working on an 80GB Samsung hard drive, model SV8004H. When a friend tried formatting it in Windows XP, it only came out as a 32GB drive. I figured she was doing it in FAT32, so I tried reformatting it in Win 98. Oddly enough, it still came out as a 32GB drive. I then noticed some strange jumper options I had never seen before - the drive can be set to master, slave, and cable select like normal, but for each one of those modes, you can also select "Lower 32GB," "Upper 32GB," or "32GB Clip." If I put a file on the drive, it will show up on the drive in any of the 3 modes. I can't figure out what these settings mean, or even if they're what's keeping me from formatting all 80GB. Any ideas are much appreciated.
Thanks,
-Matt
Thanks,
-Matt
