I've got Hard drive shutdown problem in Vista not XP "on shutdown"
4 times the drive sounds like it shuts down and spins up again the forth time it shuts down. Any one of the sounds are what you might expect the you shutdown a system, when the heads park but it does this three more times until it shutsdown.
I was thinking oh great the drive is going, but the sound doesn't sound bad or unhealthy it just shuts down and spins up and the spins up quiet and smoothe. So I just decided to try XP on the same drive same partition "formated'. So far it shuts down as normal.
Next I guess I'll try Vista with another drive.
This is a western digital WD2500JS SATA drive I've read where the YS has a problem with RAID and there is a firmware update but this is a JS and no RAID. Right now it's looking like a conflict between the OS or drivers and the drive.
I just wanted to write this down if anyone is interested for one or if anyone has experienced this or perhaps there is a setting that causes this ?? ?
Of course I'm still not discounting the drive has a problem but it tests fine and so far it only has this issue in Vista.
Well, I took the system back to where I first made an image of the vista partition and the problem is not there, I was wondering why I didn't notice it earlier. So I guess I'll just have to see if it will recreate the problem or not. So this problem may not be a Vista specific problem.
