Hi All,
I have recently (last night) put together a system with a EPOX 8k7A mobo Athalon 1.4 gig ddr with a 41.2gb IBM Ericsson 60GXP ATA-100 8.5ms 2MB cache 7200rpm Hard Drive. now when i started to install windows 98 it asked initialy did i want to enable large disk support incorrectly ( i presume) i firstly answerd no and after win98 was installed i looked at the size of the Hard drive and it was 2gb. so i started again and this time answere yes.. now the hard drive was showing on the 'My computer' screen in win 98 as capacity 31.4gb used 260MB free 31.2GB now to me this makes no sense as 1> the drive is a lot bigger 2> win 98 takes up a lot more than 260MB so i ran a Thorough Disk check which took about 3 hours and the results were:-
33,005,440 KB total disk space
0 Bytees in bad sectors
2,654,208 Bytes in 157 folders
6,176,768 Bytes in 93 hidden files
293,158,912 bytes in 3,295 user files
32,710,528 KB available on disk
16,384 bytes in each allocation unit
2,062,840 total allocation units on disk
I really want the full capacity of the hard drive and am at aloss as to why these figs do not add up. is it possible that when I fdisked I screwed something up? I have nothing on the system yet so is not a problem for me to wipe everything and start again.. but that is what I thought that I had done the second time!!!
any help greatly appreiciated.
thanks
anthony
thanks
anthony
