hard drive rRMA question
dowxp
4,568
um, ok, so its dark room right? and im trying to plug in my 75gxp in the dark. i feel resistance, so i push hard [real hard i guess] and it goes it. it posts, but does not find hd. so i take it out. and wow, the middle pin is pushed all the way in. i had put the cable backwards. apparently the cable does not have that bump thingy to protect this. now. i have a hard drive with a pushed pin.
can i RMA it? what can i do?
thanks
TunaBoo
3,280
Try to bend the pin back out. It may work, but if juice was sent it may be fried.
Generally RMA's wont cover physiucal damage such as this. So you will either have to fix it yourself, suck up the loss, or come up with some elaborate dishonst scheme to get an RMA.
neuralfx
1,636
well ive bent pins... and bent them back the upright.. at work.. and they worked fine afterwards.. you might be able to RMA, depends on which rma tech you talk to on the phone.. good luck..
-neural
