Hard Drive Reporting Failure
gijeff85
32
Hey all,
Just built a new computer and I'm getting a hard drive failure. Pulled 4 HDD's (3 500GB MAXTOR STM3500630AS and 1 750GB Seagate) from a BTX Dell Inspiron 710 XPS and put them into this system:
Intel i5-4670k
MSI Z87-G45 Gaming
Windows 8.1
Installed OS on the Seagate. Seems to be working fine. Formatted the 3 500GB MAXTOR's and all register in the device manager and on my MSI BIOS Hardware Viewer program that lets you see what all is plugged into where. Started getting the following message:
Windows detected a hard disk problem:
Back up your files immediately to prevent information loss, and then contact your computer manufacturer to determine if you need to repair or replace the disk.
Details:
Which Disk is Failing?
The following hard disks are reporting failure:
Disk Name: MAXTOR STM3500630AS
Volume: D:\
When I check the properties of my disk in volume D, it reports as working just fine. Strangely enough, I've noticed that only 2 of my 3 500GB MAXTOR drives show up on the "My Computer" screen. Even though all 3 are recognized on my device manager and in my BIOS, "My Computer" only recognizes 2 of them, drive D and E.
If D is failing, why is it reporting and functioning properly, and why is it a different drive that isn't showing up?
I also can't figure out which of the 3 is Drive D. They all have the same title. Is there a way to see which SATA port that drive is plugged into without unplugging each one individually, booting up, and seeing what pops up?
I powered down, unplugged all of them, reseated the plugs on both the motherboard and the drives, powered back up, and same issue. Any suggestions?
Thanks for the help.
CRCSUX
143
goto device manager and check the names/numbers there and then click properties and click volume then click populate, it will tell you the drive volume letter that disk is.
gijeff85
32
CrystalDiskInfo wants to install a bunch of junk on my computer.. and I got the following error message during its install:
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail.
Sorry, just built this PC today and have no antivirus on it yet. Not going to continue with that yet. Thank you for trying, though.
Clicking volumes then populate on any of my 3 MAXTOR Drives did nothing but freeze it.. didn't populate anything. The only names/numbers I see in the device manager are the same for all 3 MAXTOR Drives: MAXTOR STM3500630AS. Can't find any way to tell them apart from device manager.
PliotronX
8,883
107
Try the 2.5mb portable zip, the installer comes with a strange anime theme that wastes space anyway:hmm:
We need those SMART parameters to gauge how serious the status of the offending drive is, Windows is just throwing up a nearly useless generic error whereas CDI or anything that can read SMART like Speedfan will tell us more.
Elixer
10,371
762
Hmm, last time I installed it, it didn't install anything except the program. Where did you get it from ?
You *need* to know the SMART info, that is why it was mentioned that you should install it, and see what it is telling you.
PliotronX
8,883
107
Yeah just as a heads up, CDI, at least as of 6.0.1 which I downloaded a couple of days ago, by default and like a lot of freeware apps these days, will install toolbars. Just uncheck everything during the installation and no unintended software will make its way on your machine. I scanned with Malwarebytes and Adwcleaner after installing that way and found nothing.
Like I said though, unzipping and running that will be fast, install nothing, and has no superfluous themes.
Oh and to make the SMART easier to read, go to function..advanced..raw values and select DEC {10}
Try hard disk sentinel. Wont install xtra stuff either.
Sentinel's my fav but is not freeware. For diagnosing real quick the trial's fine but you'll like it so much there goes another $20 from your wallet :D
gijeff85
32
Here's the SMART info:
CrystalDiskInfo 2.7.5 (C) 2008-2009 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows NT 6.2 [6.2 Build 9200] (x64)
Date : 2013/11/20 5:14:49
-- Controller Map ----------------------------------------------------------
+ Intel(R) 8 Series/C220 Series SATA AHCI Controller - 8C02 [ATA]
- ST3750640AS
- MAXTOR STM3500630AS
- HL-DT-ST DVDRAM GH24NS72
- Microsoft Storage Spaces Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) ST3750640AS : 750.1 GB [0-X-X, pd1]
(2) MAXTOR STM3500630AS : 500.1 GB [1-X-X, pd1]
(3) MAXTOR STM3500630AS : 500.1 GB [2-X-X, pd1]
(4) MAXTOR STM3500630AS : 500.1 GB [3-0-0, pd1]
(1) ST3750640AS
Model : ST3750640AS
Firmware : 3.ADG
Serial Number : 3QD0Q8KV
Total Disk Size : 750.1 GB (8.4/137.4/750.1)
Buffer Size : 16384 KB
NV Cache Size : ----
Number of Sectors : 1465149168
Rotation Rate : Unknown
Interface : Serial ATA
Major Version : ATA/ATAPI-7
Minor Version : ----
Transfer Mode : SATA/300
Power On Hours : 32985 hours
Power On Count : 494 count
Temparature : 43 C (109 F)
Health Status : Caution
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : D000h [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr Raw Values Attribute Name
01 109 _92 __6 00000146CE90 Read Error Rate
03 _93 _92 _70 000000000000 Spin-Up Time
04 100 100 _20 0000000001D4 Start/Stop Count
05 100 100 _36 000000000008 Reallocated Sectors Count
07 _90 _60 _30 00003B33CA44 Seek Error Rate
09 _63 _63 __0 0000000080D9 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 0000000001EE Device Power Cycle Count
BB _96 _96 __0 000000000004 Unknown
BD 100 100 __0 000000000000 Unknown
BE _57 _42 _45 00002B16002B Airflow Temperature
C2 _43 _58 __0 000F0000002B Temperature
C3 _60 _49 __0 000005A5F243 Hardware ECC recovered
C5 __1 __1 __0 0000FFFFFFFE Current Pending Sector Count
C6 __1 __1 __0 0000FFFFFFFE Uncorrectable Sector Count
C7 200 200 __0 000000000001 UltraDMA CRC Error Count
C8 100 253 __0 000000000000 Write Error Rate
CA 100 253 __0 000000000000 Data Address Mark Error
-- IDENTIFY_DEVICE ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 5A 0C FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00
010: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20
020: 51 33 30 44 38 51 56 4B 00 00 00 80 04 00 2E 33
030: 44 41 20 47 20 20 54 53 37 33 30 35 34 36 41 30
040: 20 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20
050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80
060: 00 00 00 2F 00 40 00 02 00 02 07 00 FF 3F 10 00
070: 3F 00 10 FC FB 00 10 01 FF FF FF 0F 00 00 07 00
080: 03 00 78 00 78 00 F0 00 78 00 00 00 00 00 00 00
090: 00 00 00 00 00 00 1F 00 06 05 00 00 48 00 40 00
0A0: FE 00 00 00 6B 34 01 77 23 40 69 34 01 34 23 40
0B0: 7F 20 00 00 00 00 FE FE FE FF 00 00 00 D0 00 00
0C0: 00 00 00 00 00 00 00 00 F0 66 54 57 00 00 00 00
0D0: 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 06 00
0F0: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 09 00 F0 66 54 57 F0 66 54 57 20 20 02 00 B6 02
110: 02 00 8A 00 06 3C 0A 3C 00 00 C6 07 00 01 00 08
120: 14 13 00 30 02 00 80 00 00 00 00 00 A0 00 02 02
130: 00 00 04 04 00 00 00 00 00 00 00 00 00 12 0B 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 B1
-- SMART_READ_DATA ---------------------------------------------------------
000: 00 01 0F 00 6D 5C 90 CE 46 01 00 00 00 03 03 00
010: 5D 5C 00 00 00 00 00 00 00 04 32 00 64 64 D4 01
020: 00 00 00 00 00 05 33 00 64 64 08 00 00 00 00 00
030: 00 07 0F 00 5A 3C 44 CA 33 3B 00 00 00 09 32 00
040: 3F 3F D9 80 00 00 00 00 00 0A 13 00 64 64 00 00
050: 00 00 00 00 00 0C 32 00 64 64 EE 01 00 00 00 00
060: 00 BB 32 00 60 60 04 00 00 00 00 00 00 BD 3A 00
070: 64 64 00 00 00 00 00 00 00 BE 22 00 39 2A 2B 00
080: 16 2B 00 00 00 C2 22 00 2B 3A 2B 00 00 00 0F 00
090: 00 C3 1A 00 3C 31 43 F2 A5 05 00 00 00 C5 12 00
0A0: 01 01 FE FF FF FF 00 00 00 C6 10 00 01 01 FE FF
0B0: FF FF 00 00 00 C7 3E 00 C8 C8 01 00 00 00 00 00
0C0: 00 C8 00 00 64 FD 00 00 00 00 00 00 00 CA 32 00
0D0: 64 FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 82 00 AE 01 00 5B 03
170: 00 01 00 02 CA 03 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 02 08 08 09 08 08 04 08 04 00 00
190: 00 00 00 00 00 00 01 FE F7 00 04 00 00 00 00 81
1A0: 00 B0 1E 3F 35 1B 10 00 00 FE FF FF FF 00 00 00
1B0: 00 00 00 FE F7 00 04 00 00 00 00 00 00 00 00 02
1C0: 00 01 00 00 00 01 00 00 00 DD 43 F4 77 09 00 00
1D0: 00 9B DF 73 01 00 00 00 00 C8 80 00 00 00 00 98
1E0: AF 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AC 00
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 00 01 06 00 00 00 00 00 00 00 00 00 00 03 46 00
010: 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00 00
020: 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00 00
030: 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00 00
040: 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00 00
050: 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00 00
060: 00 BB 00 00 00 00 00 00 00 00 00 00 00 BD 00 00
070: 00 00 00 00 00 00 00 00 00 BE 2D 00 00 00 00 00
080: 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00 00
090: 00 C3 00 00 00 00 00 00 00 00 00 00 00 C5 00 00
0A0: 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00 00
0B0: 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00 00
0C0: 00 C8 00 00 00 00 00 00 00 00 00 00 00 CA 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00
Model : MAXTOR STM3500630AS
Firmware : 3.AAE
Serial Number : 9QG05LPK
Total Disk Size : 500.1 GB (8.4/137.4/500.1)
Number of Sectors : 976773168
Transfer Mode : SATA/150
Power On Hours : 33057 hours
Power On Count : 491 count
Temparature : 46 C (114 F)
Health Status : Bad
Features : S.M.A.R.T., 48bit LBA, NCQ
APM Level : ----
AAM Level : ----
01 118 _72 __6 00000B2C08CF Read Error Rate
03 _93 _93 __0 000000000000 Spin-Up Time
04 100 100 _20 0000000001BC Start/Stop Count
05 100 100 _36 000000000011 Reallocated Sectors Count
07 _55 _49 _30 07872A20CDC0 Seek Error Rate
09 _63 _63 __0 000000008121 Power-On Hours
0A _96 _64 _97 000000000000 Spin Retry Count
0C 100 100 _20 0000000001EB Device Power Cycle Count
BB 100 100 __0 000000000000 Unknown
BE _54 _40 _45 00002E16002E Airflow Temperature
C2 _46 _60 __0 000F0000002E Temperature
C3 _83 _48 __0 00000CA281F4 Hardware ECC recovered
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
020: 51 39 30 47 4C 35 4B 50 00 00 00 80 04 00 2E 33
030: 41 41 20 45 20 20 41 4D 54 58 52 4F 53 20 4D 54
040: 35 33 30 30 33 36 41 30 20 53 20 20 20 20 20 20
050: 20 20 20 20 20 20 20 20 20 20 20 20 00 00 10 80
080: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00
090: 00 00 00 00 00 00 1F 00 02 05 00 00 48 00 40 00
0A0: FE 00 00 00 6B 34 01 7D 23 40 69 34 01 34 23 40
0B0: 7F 20 00 00 00 00 FE FE FE FF 00 00 00 FE 00 00
0C0: 00 00 00 00 00 00 00 00 30 60 38 3A 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 02 00
100: 09 00 30 60 38 3A 30 60 38 3A 20 20 02 00 B6 02
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 08
000: 00 01 0F 00 76 48 CF 08 2C 0B 00 00 00 03 03 00
010: 5D 5D 00 00 00 00 00 00 00 04 32 00 64 64 BC 01
020: 00 00 00 00 00 05 33 00 64 64 11 00 00 00 00 00
030: 00 07 0F 00 37 31 C0 CD 20 2A 87 07 00 09 32 00
040: 3F 3F 21 81 00 00 00 00 00 0A 13 00 60 40 00 00
050: 00 00 00 00 00 0C 32 00 64 64 EB 01 00 00 00 00
060: 00 BB 32 00 64 64 00 00 00 00 00 00 00 BD 3A 00
070: 64 64 00 00 00 00 00 00 00 BE 22 00 36 28 2E 00
080: 16 2E 00 00 00 C2 22 00 2E 3C 2E 00 00 00 0F 00
090: 00 C3 1A 00 53 30 F4 81 A2 0C 00 00 00 C5 12 00
0A0: 64 64 00 00 00 00 00 00 00 C6 10 00 64 64 00 00
0B0: 00 00 00 00 00 C7 3E 00 C8 C8 00 00 00 00 00 00
170: 00 01 00 01 A3 02 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 01 07 07 07 07 07 07 07 07 03 00
190: 04 00 09 00 0C 05 01 3B 0D 62 39 00 00 00 00 81
1A0: 00 B3 C5 7C 1F 24 10 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 3B 0D 62 39 00 00 00 00 00 00 00 00 02
1C0: 00 01 00 00 00 00 00 00 00 AA 8B 03 1E 00 00 00
1D0: 00 E6 59 03 00 00 00 00 00 20 81 00 00 00 00 BE
1E0: 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00
000: 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 26 00
Firmware : 3.AAE
Serial Number : 9QG06VD9
Power On Hours : 33056 hours
Power On Count : 492 count
Health Status : Good
APM Level : ----
AAM Level : ----
01 _99 _71 __6 0000088AE0F9 Read Error Rate
05 100 100 _36 000000000000 Reallocated Sectors Count
07 _63 _60 _30 0000001EFD7E Seek Error Rate
09 _63 _63 __0 000000008120 Power-On Hours
0C 100 100 _20 0000000001EC Device Power Cycle Count
BE _54 _33 _45 00002E17002E Airflow Temperature
C2 _46 _67 __0 000F0000002E Temperature
C3 _70 _46 __0 00000B2A8C8A Hardware ECC recovered
020: 51 39 30 47 56 36 39 44 00 00 00 80 04 00 2E 33
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 1B
000: 00 01 0F 00 63 47 F9 E0 8A 08 00 00 00 03 03 00
020: 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00 00
030: 00 07 0F 00 3F 3C 7E FD 1E 00 00 00 00 09 32 00
040: 3F 3F 20 81 00 00 00 00 00 0A 13 00 64 64 00 00
050: 00 00 00 00 00 0C 32 00 64 64 EC 01 00 00 00 00
070: 64 64 00 00 00 00 00 00 00 BE 22 00 36 21 2E 00
080: 17 2E 00 00 00 C2 22 00 2E 43 2E 00 00 00 0F 00
090: 00 C3 1A 00 46 2E 8A 8C 2A 0B 00 00 00 C5 12 00
180: 00 3C 00 00 00 03 07 07 07 07 07 07 07 07 00 00
190: 00 00 00 00 00 00 01 14 91 75 37 00 00 00 00 81
1A0: 00 02 CC D4 0A 24 10 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 14 91 75 37 00 00 00 00 00 00 00 00 02
1C0: 00 01 00 00 00 00 00 00 00 FD 62 05 4A 00 00 00
1D0: 00 54 A2 03 00 00 00 00 00 20 81 00 00 00 00 F9
1E0: 1B 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 00
Firmware : 3.AAE
Serial Number : 9QG07N64
Temparature : 42 C (107 F)
APM Level : ----
AAM Level : ----
01 117 _79 __6 000008322BEF Read Error Rate
03 _94 _93 __0 000000000000 Spin-Up Time
04 100 100 _20 0000000001BE Start/Stop Count
05 100 100 _36 000000000002 Reallocated Sectors Count
07 _90 _60 _30 0000393883D9 Seek Error Rate
BE _58 _35 _45 00002A16002A Airflow Temperature
C2 _42 _65 __0 000E0000002A Temperature
C3 _85 _46 __0 00000A26951D Hardware ECC recovered
020: 51 39 30 47 4E 37 34 36 00 00 00 80 04 00 2E 33
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 35
000: 00 01 0F 00 75 4F EF 2B 32 08 00 00 00 03 03 00
010: 5E 5D 00 00 00 00 00 00 00 04 32 00 64 64 BE 01
020: 00 00 00 00 00 05 33 00 64 64 02 00 00 00 00 00
030: 00 07 0F 00 5A 3C D9 83 38 39 00 00 00 09 32 00
070: 64 64 00 00 00 00 00 00 00 BE 22 00 3A 23 2A 00
080: 16 2A 00 00 00 C2 22 00 2A 41 2A 00 00 00 0E 00
090: 00 C3 1A 00 55 2E 1D 95 26 0A 00 00 00 C5 12 00
180: 00 00 00 00 00 03 07 07 06 07 07 07 07 07 00 00
190: 00 00 00 00 00 00 01 98 8C B3 39 00 00 00 00 81
1A0: 00 47 2D 21 F3 23 10 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 98 8C B3 39 00 00 00 00 00 00 00 00 02
1C0: 00 01 00 00 00 00 00 00 00 A5 FD 3E 38 00 00 00
1D0: 00 BB 59 03 00 00 00 00 00 1F 81 00 00 00 00 00
1E0: 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BF 00
PliotronX
8,883
107
The second drive flagged as bad is what is causing Windows to throw up errors. It has 17 reallocated sectors which is 19% of the reserved sector space and is not in of itself bad unless they cropped up suddenly at once or in a short time frame. If they were suddenly onset, the drive has a 70% chance of crapping out within six months. Two of the drives also have fewer reallocated sectors. Overall I would only worry about the bad drive but make sure data on all of them is backed up.
Oh and set your defragmentation to less frequent intervals so they are not unduly stressed.
Elixer
10,371
762
Well, the good news is, you have 1 good HD. The bad news is, you have 1 bad, and 1 of questionable quality, but since a HD that has faulty SMART data can never get better.. .might as well use that drive as only a scratch drive.
As said by Plioxtronx, backup ASAP if you haven't done so, then buy 2 new HDs.
Should have said to post a screenshot, not a ASCII dump. :)
gijeff85
32
Great thanks guys. Now my next question- how do I figure out which one of those is the good one? I'm going to trash the other 3. Already have a new 2TB drive on the way.
PliotronX
8,883
107
Firmware : 3.AAE
Also those temps are pretty high for mechanical drives. You want to keep them as close to 30 degrees as is possible. A single quiet fan is all that's needed, nothing crazy. If you have a placement with a size we can recommend a good inexpensive fan.
gijeff85
32
I'm sorry, I meant to say how do I find out specifically which drive is it in a physical sense - I've got 3 MAXTOR's plugged in. How do I find which is the good one in my case? Is there a way to track which SATA port it is in?
PliotronX
8,883
107
Ah okay, can't tell from that output but they are sorted in a similar way on CrystalDisk, at the top where you select the drive, it's going to be the third from the left. That drive letter should reveal which port it's plugged into with device manager. Otherwise you'll have to inspect the white labels on the drives and look for the serial number 9QG06VD9.
gijeff85
32
It was the third in line, just like you said. Confirmed with the serial number. Thank you! Going to save that one and pitch the rest.
As far as my case, I have a Corsair Carbide Series 300R Windowed. Any inexpensive fans you know will fit that to help with temps? I'm so close to having my first PC build a success!
PliotronX
8,883
107
Awesome, no prob! Nice case, it has front intake placement for either 120mm or 140mm fans and depending on your size preference (larger tends to have lower noise and move more air), I am a fan of Yate Loons (120mm & 140mm) and this Silverstone fan would suit well.
fzabkar
173
46
101
The MAXTOR STM3500630AS, serial number 9QG05LPK, is being flagged as bad because the value of the Spin Retry Count attribute has fallen below the threshold (96 versus 97). The Reallocated Sectors Count is only 17 (= 0x11) and has not made any appreciable inroad into the total available spare sector count. If it had, then the normalised value would have dropped below 100.
IMHO the ST3750640AS, serial number 3QD0Q8KV, is the worst of your drives. Both the Current Pending Sector Count and the Uncorrectable Sector Count attributes are sitting at the threshold.
