Originally posted by: birdpup
Originally posted by: ingeborgdot
So two extended partitions? Why extended over primary?
A hard drive can only contain 4 primary partitions. This is a physical limit based on physical hard drive design. Because of this 4 partition limit and the need for more partitions, the extended partition was developed. Any number of extended partitions can be created but they all need to be contiguous to each other.
If you do not expect to require more than 4 partitions on this drive, you can safely create a primary partition. If you may need more than 4 partitions, then the Windows XP system partition is required to be primary, after that you are free to make any number of extended partitions you may need for now or the future.
Many of these questions are elementary disk partitioning questions and the answers can be found on many webpages devoted to this topic by googling for them.
drive partition partitions partitioning
drive partition
drive partition strategy
drive partition primary extended
