Hard Drive Problems
MGalang
34
Hi,
I need help w/ a hard drive issue. I installed a new master drive and decided to use the Western Digital EZ-Install instead of FDISK. It wanted to copy files from a bootable drive (my old one) to make itself bootable. So I partitioned it w/ the program and then saw it was copying the whole first partition of my old HD. I decided to cancel. So I continued to put a fresh install of Windows XP. Then I saw my whole old Hard drive w/ 3 partitions of information was reduced to 1 1.96 GB partition. My old drive is 30 GB!!! So I seem to have lost the information. I went to FDISK and saw that all the partitions had become NON-DOS 100% used drives. Not a good sign. I proceeded to delete them and make new ones. But it's restricting me to the 2 GB I saw before. It says there are 30 GB but the max size partition I can make is 2 GB. How can I get the rest of my HD back? I got EasyRecovery Professional software to try to get back my files but first I need to recognize my whole HD. Need Help Please!!!
Thanks,
-Michael
DaiShan
9,617
I am not sure what you are trying to do, are you trying to create 3 partitions, and install the OS on one?
MGalang
34
I installed a new hd and installed the OS on that one. I'm trying to "resurrect" the old hard drive and it's 3 partitions but it's only telling me I can make a partition upto 2 gb, which is not the 30 gb it really is.
MGalang
34
Ok, I got FDISK to say I have a 30 GB drive but Windows XP still sees the drive as a 1.96 GB unformatted drive. I have formatted through DOS twice, and that hasn't done anything. I tried re-installing WinXP. That has done nothing. Is there any way I can save this drive? I know it has to work cos it was just recently working and only went haywire when I installed the new drive and cancelled the copy process. Any help would be appreciative.
-Mike
mee987
773
go to control panel->administrative tools->computer management->storage->disk management
this is win2k/xp's fdisk, you could say... anyway, from here you can delete, create, and format partitions all without ever restarting
MGalang
34
the thing is WinXP doesn't recognize it correctly...I seem to have new problems now...It takes a really long time to start windows now and when it finally does boot, the mouse doesn't work...I tried a re-installation of WinXP but now the setup program doesn't work...after it loads drivers and just says starting windows and stalls
