Hello everyone. I recently built a media center PC with the following components:
- AMD A4-3400 2.7Ghz
- ASRock A75M-ITX
- Corsair 4GB (2x 2GB) DDR3 1333 Memory
- Western Digital Caviar Green 500GB
- APEX MI-008 Mini-ITX
- Sony BWU-500S Blu-Ray Burner
- Windows 7 Ultimate
Now, the problem I've been having since Day 1 is that my HDD NEVER boots into the OS on the first try. I get stuck on the BIOS screen and the HDD light doesn't activate. I have to manually reboot by holding the power button, and the OS loads just fine on the second attempt. This happens like clockwork every time. Additionally, if I put the computer to sleep (either manually or because of prolonged inactivity), it will not wake from sleep. I've tried using the keyboard to wake it, as well as pushing and even holding the power button. Nothing happens. I have to disconnect the power cord. Then, when I reconnect it, it resumes from its sleep state.
Any help would be greatly appreciated!
Edit: Also, I have two external drives connected to the PC via USB
- ASRock A75M-ITX
