First here is my setup:
Primary Master: WD 40GB, C (system) and D (Files) partitions
Primary Slave: FAILING Seagate 10GB, H (system backup)
Secondary Master: WD 120GB, E (Big Files), I (Photoshop scratch)
Secondary Slave: CDRW
Ok now the problem.
My Seagate is going out on me. It sometimes clicks and spits and sounds like Chewbacca. When this happens the system freezes, and I get a blue screen with ?Kernal_stack_inpage_error?.. Beginning dump of physical memory?
If I try to disconnect the IDE cable and power from this drive, my system will not boot. It takes about 30 seconds for the bios to recognize the remaining drives, then I get the post screen and it says ?verifying dmi pool data?, then moves on to boot from CD.
If I try to inspect the drives from a startup disk, the WD 40BG is not recognized, and if I insert my Windows2000 disk and try to repair, it does not recognize a system disk or current OS instillation.
Well that?s all I know, if you have any suggestions as to what is up or what I need to do, it would be appreciated.
Ok now the problem.
