Hard drive Problems
Crew
Banned
Mar 13, 2004
102
]]]]EDIT[[[[[
All i did was manually initialize the drive, partion, and format with disk management. Problem solved. :)
I have a 33.3Gb Harddrive, and i'm trying to install a 80Gb harddrive. This is my setups i've tried and thier results.
33.3HD jumper set to Master on the master cord, 80Gb jumper settings set to Cable select on slave cord.
I booted up, and now its showing Local Disk E:/ which is the 80gb as nothing, 0.00Kb to be exsact
33.3HD jumper set to Master on the master cord, 80Gb jumper settings set to Slave on slave cord.
Black screen poped up, and notified me that the Operating System was missing.
33.3HD jumper set to Cable Select on the master cord, 80Gb jumper settings set to Cable select on slave cord.
33.3HD jumper set to Master on the master cord, 80Gb jumper settings set to Master on Seprate IDE cable
This gave me nothing.
So the only setting that worked was using Master, and Cable select setup which left me with the drive showing as 0Free Space, and 0Used Space. I would have guessed that Master/Slave setup would have worked but no. I figured it was trying to read the boot sector on the new Harddrive thus giving me an error about not finding the O.S. Any help?
\\\\Edit in
both drives show up as working properly on device manager
\\\\\Edit in
Well ok I got it showing space on it now, but its only 1.60Gb
