I built a comp for a friend earlier this week (specs below), and it seems to have a hard drive issue, but I am not sure since I've never had the problem, so I thought I'd ask here. The hard drive will format and Windows will install correctly, but after a couple of restarts the system acts as if it forgets files. I boot into Windows and I'll try to run Call of Duty and it will give errors claiming 162 sound files are mising or something similar. I'll restart, and I'll be able to run CoD, but I won't be able to run something else, and sometimes it will forget certain Windows files on boot giving me BSoD's. I reinstalled and reformatted several times, trying various things that I didn't do before (ie: loading raid drivers before install) and that didn't do much. The order in which I install drivers is Windows SP2, Chipset, Network, Windows Update, Video, then the rest of the drivers. Imo, it's either a bad motherboard or bad hard drive. Has anyone else ever had this problem?
Specs:
DFI UT nF4 SLI-DR Motherboard
AMD 64 3200+ Socket 939
Corsair XMS 2x512MB DDR400
MSI GeForce 6600GT 128MB PCI-E
Maxtor 300GB DiamondMax10 w/16MB Cache
Specs:
