littletemple
I've got a strange hard drive. Just recently I began to hear some loud noises coming from one of my hard drives. So I rebooted and it took awhile to load up. That drive didn't show up, so I turned it off. The next day, I turned it on and the O/S recognized the hard drive, but it was still making those noises. I know that the hard drive is probably going to die soon. What I wanna know is what I could do now to possibly save some of the data on that drive or even save the drive itself? Right now, windows ain't recognizing it and it's still making wacko noises. I've read this on some website:
Remove the hard drive from the drive cage and tap firmly with a knuckle on the outer casing (not hard enough to damage the unit). The shock may free any stuck mechanisms.
Place the hard drive upside down in the drive cage. This causes a slight change in head geometry due to gravity and can occasionally solve the problem.
Putting the hard drive in a waterproof bag and then sticking it in the freezer overnight and then straight back into the PC. If you are lucky, this method may work and will allow you to quickly transfer the data before it dies again. The physics behind the method is unknown, but could be related to the expansion/contraction of the metal components inside freeing any mechanisms. This has been reported to work quite often, but the effects will not last for long at all.
Any comments on those methods?
