- Feb 9, 2003
- 64
- 0
- 0
Hi everyone,
I have a WD1200JB. I've posted this problem before, but I was just wondering if I can get some additional feedback.
Basically every once in a while (like maybe once in a week) my computer would freeze entirely... and reboot by itself. After doing this and when my system is trying to boot up again, it won't detect my WD1200JB hard drive anymore (as if it's not there) and hence it will not boot. Soft rebooting doesn't solve the problem. Only if I turn the computer off and then turn it back on, will my system then detect the HD and everything run normally again.
I ran the Datalife diagnostics program from WD and the drive appears to be alright.
From the previous post... I've been suggested to change the ATA cables, which I did - that has not solved the problem. Another suggestion was to change the Power Supply - which I have not done. I'm contemplating doing this now.... but before I do venture out into spending some money on a new PS... can I get some additional feedback as to what else could possibly be the problem? Could be it a defective HD?? Or is it definitely the PS? Thanks a lot for any input.
