I am building a new system and can't seem to get the hard drive to work properly to setup windows. Whenever I fdisk c: i get "NO FIXED DISK PRESENT." Also when I setup I get this "If you have HPFS or NTFS installed on your hard drive, you will need to create an MS-DOS boot partition to set up windows."
I have created a primary boot partition on this hard drive on another system. When I run windows or type DIR on the other system it doesn't work. I then installed the hard drive back on the new system and I have the problems listed in the first paragraph. I have no other ideas so please help me.
The BIOS recognizes the hard drive.
The virus checker is disabled in the BIOS.
Here is the system:
ASUS A7A266 mainboard
1.2 GHz 266 FSB processor
Western Digital 20 gig hard drive
Here is the system:
