ahallanandtech
I monitor my hard drives' S.M.A.R.T. status with Crystal Disk Info. I've encountered a number of hard drives with "Pending Sector" errors that seemed also to crash the hard drive. In one case, after finding twelve pending sector errors, I ran chkdsk in Windows and although it "recovered" five or six files, it also corrupted them and made them useless (I had backups). In another case, I had a laptop drive that would blue screen however you tried to boot it (even in safe mode); I cloned this drive to another that that one booted right up. The original drive had one pending sector error.
However, after running DBAN on both failed drives to blank them out, all of the pending sector errors disappeared. I might have expected that they would have been replaced by spare sectors, but according to CDI, neither drive has any reallocated sectors or any other S.M.A.R.T. errors anymore.
So how should I view these drives for future use? One was a few years old but the other is only about 6 months old - still under warranty but I can't RMA it I imagine with no errors anymore (it also passes the Western Digital diagnostic with no errors).
Pending Sectors are sectors on the drive that cannot be read, right? What causes them? If blanking these sectors does not cause them to be deactivated by the drive firmware and replaced (as seems to have happened with these two drives), should I assume those sectors are really OK? I had assumed that such drives were basically dying and I should probably recycle them - but could such errors just be glitches that could appear from time to time and not indicate pending hardware failure of the drives, making them no more likely than any other drive to fail in the future?
Thanks for your insight!
