- Dec 25, 2000
- 1,150
- 14
- 81
Ok....here's the story. I have my friend's computer here at my house(he never uses it). It was going to be used earlier tonight and it had a corrupt file. I decided that this would be a PERFECT time to try XP. That didn't quite pan out and so I tried Win2k. That also didn't quite pan out so I was just goofing around and decided to try Mandrake 8.2. And.....much like the other two OS's I didn't have enough room(the computer only has a 1 gig drive). So.....I decided Mandrake wouldn't work and I'd just put Win98 back on. Well, I put in the Win98 boot disk and after loading the tools.....it told me that it wasn't a FAT partition. I went in and used Fdisk to delete the non-dos partition. This is where the problem starts. I set up a primary partition but it was only about 500 megs of the drive. The other 500 megs was on an extended logical drive. I can't get rid of the logical drive or the extended partition. It won't let me do anything. When I go to delete the extended partition, it tells me that it can't delete an extended partition when there are logical drives. When I go to delete the logical drive, it doesn't show a logical drive. I would like to put the entire partition(of a whopping 1 gig) into one drive so I can put Win98 back on. I haven't had any success getting rid of the logical drives or the extended partition......especially now that I have the primary partition.
Any help would be GREATLY appreciated! Thanks in advance!
jc
jc
