Hard Drive not recognized
Maxinator
9
I built a new machine and reused a hard from another machine..
The new machine does not recognize the drive at startup, but it does show up in the BIOS.
Any suggestions?
Many Thanks
D
ch33zw1z
39,540
20,188
Did you reuse this hdd for the OS, or just as a spare?
Mobo? HDD? What OS?
Gotta have more info to help you out.
jackschmittusa
5,972
If the bios recognizes it, I would say the "machine" recognizes it. What in particular does not see it?
Maxinator
9
Yes I did reuse this for the OS and other software I had installed.
The MB is the Asus Maximus Formula, HDD is WD 500GB Cavier SE and the OS is WinXP x64.
Thanks
Maxinator
9
After POST, the screen says no drives found then continues and says please insert bootable media
ch33zw1z
39,540
20,188
so the BIOS sees hdd, but it won't boot to the hdd. Have you installed the OS since you upgraded? How's it "seen" in BIOS, as a standard disk or as a RAID disk?
Harvey
Administrator<br>Elite Member
67
I just posted the following reply in your thread in another forum where you posted a little more info about your system.
You didn't say whether your drive is SATA or PATA. If it's PATA, be sure the jumper is set correctly as Master, Slave or Cable Select.
Three issues to consider in PATA setups:
1. When using Cable Select, the system will recognize the drive at the far end of the cable as the Master, and the one on the middle connector as the slave. If you have two drives on the one IDE channel, setting either drive as anything other than CS could screw up the way the board recognizes one or both drives.
2. If the physical layout of your setup doesn't allow easy routing of the cables to accomodate the above connection order, you should set the jumpers on each drive as Master or Slave. This forces the priority order, regardless of which connector is attached to which drive.
3. I've seen some boards, even newer ones, that don't handle Cable Select well. Sometimes, it's only with particular brands of drives. I can't recall which boards and which drives, but I know I've seen the problem on a few Asus boards and with a few WD drives.
This may not be the problem, but if setting the jumpers to force the Master/Slave assignment works on your system and Cable Select doesn't, you'll have your answer.
Good luck. :)
Maxinator
9
I used the disk as a dual boot on my other computer. I had XP and XP x64 dual boot.
It is seen as a standard disk
jackschmittusa
5,972
It likely needs sata drivers that are specific to your new mb to see the drive now. You are going to have problems with the other drivers left form your old mb too. You may get away with a repair installation of both OSes. If not. then it is time for a clean install.
