First of all this is a continuation of this thread http://forums.anandtech.com/messageview...atid=32&threadid=1978472&enterthread=y
but its mostly a new issue so im starting a new topic. No need to read last topic
Randomly the computer would not boot up, as soon as the xp flash screen loads it will restart and last know config and safe modes do not work. I tried to go do a repair install but xp setup only sees my ATA HD and not the SATA HD with the xp install on it. I thought the drive or cables might be bad, but the BIOS and a knoppix live CD work fine with the drive, i was even playing songs off it from knoppix. It seems that its not a hardware issue with the PC not starting and a repair install should work. Im using Asrock 939 dual SATA 2. I dont believe i need to use the F6 install feature for raid drivers if the HD is not in raid, Correct? What should i do next.
