Hello all,
My saga of trying to install a new hard drive continues. I have the following computer configuration:
Abit KR7A Raid with Athlon XP1700+
1 GB Crucial DDR Ram
Windows XP Pro
Boot drive WD 100GB 2MB buffer partitioned into C: (25GB, system) and Z
75GB) with NTFS and Partition Magic 7 (on Highpoint raid controller, primary master)
2nd physical drive Quantum Fireball 30GB (primary slave)
IDE floppy drive
Lite-On 241040 on IDE (master)
ATAPI 44X CDRom on IDE (slave)
Dell USB keyboard
Logitech USB scroll mouse (hooked to the keyboard)
I was planning to install a 2nd WD 100GB 2MB buffer drive as a RAID drive but reading about data loss issues with RAID 0 and reduced disk space with RAID 1 (essentially halved) I decided to give up on RAID. I wanted to install this hard drive as a 3rd physical drive. I hooked this up to the other Highpoint RAID controller IDE slot as a secondary master (initially one drive only and then as cable select on the hard drive jumper pins). However Windows XP does not show it in the My Computer listings. It does appear in the initial boot screen and also under Windows System device listings. However in this listing 'Use this device' option is greyed out and I cannot enable it.
Is there a 4 IDE device limit for my configuration and have I exceeded it? Is there any way around it?
I also have a problem using my keyboard during the initial startup process to access the BIOS. I've never really had to adjust the BIOS but I was wondering if my 2nd IDE controller is disabled in BIOS. However I can't get to the BIOS setup at startup. Do I have to use a PS/2 keyboard at boot up to access the BIOS? I've read somewhere that USB keyboards may not be enabled at startup in some BIOS'. I have the original Abit Award BIOS that came with this board.
Thanks for all the help.
Windows XP Pro
IDE floppy drive
Dell USB keyboard
