Hard Drive MTBF Ratings
Slaimus
985
All the consumer-level HDs have a rated MTBF of 600,000 hours. How in the world did they get this number? No hard drive is going to last 60+ years. My DVD drive has a 50,000 hour MTBF, which looks a lot more realistic.
Maximilian
12,604
15
Hmm 68.681 years, yea that sounds bullsh!t. I thought the MTBF was around 40-80 thousand hours for HDD's where did you see the 600k rating?
Slaimus
985
Just google hard drive MTBF. WD's Raptors/RE and Maxtor's MaxLines claim 1.2M hours.
Here is the page for Samsung
Maximilian
12,604
15
The enterprize drives from western digital also claim 1.2million hours, actually thats probably believeable since theyre designed for large corporations with servers that need to last a long time, maybe not 60 years but thats impressive it these drives actually can last that long.
Pariah
7,357
20
MTBF does not apply to single drives. MTBF is a reliability rating for a large group of drives (technically the whole family of drives). Even then the rating is only valid within the service life of the drives, which is 5 years for practically all standard ATA and SCSI drives. If you had 1000 WD Raptor, w/ a MTBF of 1.2 millions hours, running 24-7 in a server farm, you should expect one to fail every 50 days (1200 hours). To try and apply this rating to a single drive, you would have to replace the drive every 5 years. If you did that, then you should expect one drive failue ever 137 years or so, keeping in mind you actually went through 28 drives during that period of time.
zephyrprime
7,512
Even by that way of figuring MTBF, the numbers are still BS. I did helpdesk support for 7000 seat company and the site I was at probably had about 1000+ people and computers in it. I probably did a HD replacement once a week and the other 2 guys that worked there did also. If the computers are on for 8hrs a day & 5days a week, that works out to one failure every 13333 hours of operation. No where near the rated MTBF.
Needless to say, MTBF figures are bigger BS than LCD response times and Apple performance claims.
Also, all the manufacturers list similiar MTBF figures even though at storage review, the reliability survey database shows drastic differences in reliability from model to model.
I bet they do all sorts of realistic things to calculate these numbers. Like they could extrapolate the figure only from new drives which since they are new a less likely to fail. Also, I notices that the wording on the samsung site was "power on hours". It doesn't mention time in actual USE. A drive could last a long time if it were turned on but never had to perform any reads or writes. Then there's the possibility of outright lying.
Slaimus
985
The problem is, how come HDs get away with a completely different definition of MTBF.
Pariah
7,357
20
You're taking the MTBF a bit too literally. It's not that the companies are lying, you have to understand that the quoted values on spec sheets are theoretical MTBF, not operational MTBF. Why are they theortical? Well, if you have ever looked at the specs of an announced new family of drives before it is released, you will likely see a MTBF spec on there. Obviously there is no way a HD manufacturer can know how a drive is going to perform in the field for certain before it is ever released into the field. So they use a number of techniques to guestimate what the value should be. Things like how previous/similar drives performed, component failure rate, and limited in house testing for a limited period of time (a few thousand drives for a few months) are used as a model for determining what the MTBF should. Still, no matter how accurate they make their model it's still just theoretical.
That said, you can pretty safely assume that on average a drive with a 1.2 million hour MTBF will fail less frequently than one with 500,000 hours. If the difference is like 100,000 hours, that's not a statistically large enough gap to declare one drive likely more reliable than the other.
If you're only getting about 13,000 hours, either you're not calculating your failure rate accurately, there was a defect in the drive run, there is something in your environment that the MTBF model didn't account for, or some combination of all of those and other variables contributed to the difference.
For example?
Googer
12,576
7
Specification
Reliability Specification
Non-recoverable Read Error
1 sector in 1014 bits
MTBF- 600,000 POH
Start/Stop Cycles (Ambient)
50,000
Component Design Life- 5 years
Zepper
18,998
Look on StorageReview.com for real-world reliability ratings. You'll have to register to use their reliability database.
remember, the mfr's are taking units right off the line for their life testing. I'm a firm believer that shipping knocks substantial life off most drives that reach an end-user's hands. Shipped from mfr. to distributer, then distributer to online retailer, shipped again from there to you - could even be another leg in there if it goes to a big box-builder... It's a wonder they work at all.
.bh.
