- Jan 21, 2002
- 3,701
- 0
- 86
I remember reading somewhere that hard drives that were mounted horizontally (flat) tended to have higher reliability than those mounted in a vertical fashion (on their side). Something about the vertical mount putting more strain on the read head or the motor.. Is there any truth to this? Is it even an issue? I've always tried to buy cases where the hard drives mounted horizontally, but this morning I put together my new 3400+ rig and I've got a problem. I bought a Raptor, so now I've got 3 hard drives but my 6800 GT is so freakin long that it won't allow me to install a drive in the middle slot of the HD tray. I can BARELY squeeze the card in there with a drive in the middle slot, but there's NWIH that I'll be able to connect the power connector to the end of the card.
My temp. solution was just to leave 1 hard drive out for now, but I might just get a different case so that I can have all 3 drives installed. I've found a Lian-Li that I like, and it holds up to 5 hard drives (none of which would conflict with the vid card) but the HD tray is a vertical-mount design so they are lined up side-by-side. If the vertical mounting method is bad for reliability, I'll just shop for another case that has a horizontal mount system that's in a location which doesn't conflict with the vid card.
Thanks!
Thanks!
