Making matters worse, the 40-conductor IDE/ATA cable select cables have the "master connector" as the middle device and the "slave connector" as the device at the end of the cable, farthest from the host. For signaling reasons, it's best to put a single drive at the end of a cable, not put it in the middle leaving a "stub" of wire hanging off the end of the channel. But if you do this, that single drive sets itself as a slave with no master, a technically illegal configuration. Worse, suppose you do this, and your hard disk sets itself as a slave, and the system boots from it without problem, as most would. Then, you decide to add a new hard disk. You set it to cable select and attach it to the middle connector. The new drive then becomes the master, and thus moves ahead of the old drive in precedence! The system will try to boot from it instead of your old drive (which some people might want, but many do not.)
