Hard Drive Keeps Dissapearing
Scootin159
I have 2 Seagate 80GB HDD's on IDE 0 (master & slave). The Slave one keeps on disappearing on me though. Anyone have any ideas on what could be causing this?
Edit: Sorry about the short first description, here is a move verbose explanation of the problem.
I will be using windows right along without a problem....then it will randomly lock up (have to hit reset button).
Then when I reboot the disk will not be reconized via the BIOS.
I try rebooting again, turning power on & off, ect...nothing helps
If I boot with the HDD disconnected, and then boot again with power on everything is fine again.
Any ideas?
BTW, I tried various IDE cables as well, and am running a Iwill KK266 (Via KT133a chipset) w/ the latest BIOS. I'm also running windows XP w/ the latest VIA 4-in-1 drivers.
What OS are you using? Is the BIOS still "seeing" it? Are your jumpers correct? I
f your jumpers are corrrect and the BIOS doesn't see it I fear the worst...
The drives aren't clicking or scratching are they?
Also, are they overheating? What speed are they and how close together are they in your case?
<< The drives aren't clicking or scratching are they?
No clicks, no overheating (drive is cool to the touch), drives are mounted with a empty bay between them & a 80mm fan blowing over both of them (so they're cool enough).
