I just replaced the hard drive in a friend's computer because her's was full. I've run into an issue I've never seen before and hope someone here can explain it to me. We used the software that came with the new drive (a Western Digital) and just moved everything from the old to the new. That all went smoothly. Then I changed the jumpers and the position on the IDE cable for both drives, making the new one the primary master and the old one primary slave. Booted up and everything was fine. So I reformatted the old drive, then removed it from the computer. I then rebooted the computer and went into the bios and had it detect the drive. But it wouldn't detect it at all! It detected the CD-
Rom drives ok, but not the hard drive. I then tried resetting the CMOS but still no luck. I put the old drive back on as primary slave and now it will boot! Took it off again, and no luck. I even tried using a different hard drive and installed it as primary slave and it also worked.
Now I've got the new drive as primary master and the old drive as primary slave. But if I take out the slave drive, the new drive isn't detected. I've done this same procedure with another drive before this one with the same problems. I thought maybe it was caused by the first drive I used (a refurbished Maxtor and a used IDE cable) so I bought the new Western Digitial and used the new cable.
Does anyone have any ideas what's going on here? It's really got me scratching my head.
Thanks!
Thanks!
