Hard Drive is SLOW
I was having some major slow downs when doing HD intensive processing, like making a Divx for example....it goes slugglishly slow....i installed nero(even though i dont' have a burner) to check my drive speed, all thee drives are going at 4mb/s. I have a Maxtor 1.2gb, a Quantum 3gb, and a Quantum 30gb.......the last one is the one i'm concerned about...since that's where i do most of my stuff from. My brother has the same line of HD, only a 40gb, and he acheives 33mb/s on his, and i'm thinking this would help me TREMENDOUSLY if i could get this speed up. I'm using a Soyo k7-vta-b mobo with a duron 800@850. I don't know if i installed the HD support or whatever for my motherboard...but i bleive so......what can i do to speed myself up? Thanks
its sounds like your drives are using PIO instead of DMA
go into the bios and check to make sure DMA is enabled.
Also make sure you are using a ATA 66/100 cable. It should have 80 wires instead of 40.
<edit>
Here is a quick picture I just snapped. You will have to look carefully, as my camera kind of, how shall we say... blows 🙂
REgular cable on left, ATA 66/100 on right WArning, this is on my own Server on a DSL, so it will be slow to download.
</edit>
<< Also make sure you are using a ATA 66/100 cable. It should have 80 wires instead of 40.
<edit>
</edit>
Okay, i'm going to go reboot and check my BIOS, see what that shows up, and then i'll have to do surgury to make sure i'm using a 66/100 cable.....i think i am though, i've got one with fat wires, and then one with lots of thinner ones...i'm assuming that's the one i SHOULD be using on my faster drive......so be back, if i don't come back, .......well lets not think like that....wish me luck
PS you're right, it is slow 😉
<< its sounds like your drives are using PIO instead of DMA
Well, both the PIO and the UDMA options are set to "auto" I can either disable UDMA, or select a mode for my PIO
I looked as it was booting up, and heres' what we've got:
Primary Master: 1.2gb is set to PIO4 Drive C
Primary Slave: 3.0gb is set to ATA 33 Drive E
Secondary Master: 30gb is set to ATA 66 Drive D
Secondary Slave: DVD is set to ATA 33 as Drive F
All drives read at 4mb/s.....
Motherboard specs
any programs or anything i can use to see my settings and what i can do to speed it up? I dont' think it's my cable....
how are you benchmarking your hard drives with nero? i dont see an option for that anywhere....im also curious since my hd seems to be going kinda slow also....need something to benchmark it under xp...
<< how are you benchmarking your hard drives with nero? i dont see an option for that anywhere....im also curious since my hd seems to be going kinda slow also....need something to benchmark it under xp... >>
Under the copy CD option in the wizard, go to the image tab, and click the button for "test drive speed" or something similar to that.....
Sweeet, solved my problem, I went back and installed the DMA drivers that came with my mobo....stpuid me.....that solved the speed problem, i now get 4mb/s, 12, and 34, for my drives...BIG difference.....that caused a problem with my DVD drive, for which i had to uncheck DMA in the system > device manager > cdrom drives > settings > DMA....
Now i'm rocking ;-) Thanks all for your help
