BarnyardMonkey
Was hoping maybe there is a tweak of some kind to get this problem fixed.
after installing XP pro on one of my new systems,the HD is going crazy.
HD is doing alot of tasking just sitting idle,or after loading up a program (Cool Edit Pro),the HD led will keep flashing for quite some time even after the prog is loaded and sitting idle.
even just browsing the net it will start tasking alot.HD gets loud and led constant blinks.
have tried a system before this one with XP Pro and it did the same thing.
i switched back to Win98SE in that system.
was hoping to stay with XP with this one.
Specs:
WinXP Pro
MS-6330 Socket A Board (OEM) - Not the Lite version,and no Onboard Sound (Bios is 7.00.xx i think)
Tbird 1Ghz
384Mb PC133
15G IDE IBM 7200RPM HD ATA/33
Geforce2 GTS 32Mb AGP
SB Live! X-Gamer 5.1
48x IDE Cdrom
10x DVD-Drive
All latest Drivers (Vid,Sound,NIC)
If anyone might know what the problem is i'd appreciate it.
Shawn.
Specs:
WinXP Pro
Tbird 1Ghz
384Mb PC133
48x IDE Cdrom
10x DVD-Drive
Shawn.
