- Aug 29, 2004
- 15
- 0
- 0
Ive had 2 WD drives die on me, ive RMAed again and waiting on the 3rd WD drive to arrive next week, its a WD1200JB SE 120gb btw. Im currently using an old Maxtor 5400rpm drive from my old pc which is 5 years old and ive had ZERO problems with it in 6 months. Am i having a power supply issue with the newer WD 7200rpm drive or am i having bad luck? Specs below thanks...
Athlon 64 3000+@2.0ghz(stock)
Evga 6800GT 350/1000(stock)
Asus K8N-E deluxe nforce 3 250gb mobo
pc3200 ddr400 1024MB(2x512) XMS Corsair memory
80GB IDE Maxtor HD
Lite-on DVD/CD RW
Sound blaster audigy 2 zs
Antec SLK3700-BQE Case with 350W PSU(21a on 12v)
Windows XP SP1, directx 9.0c, Nvidia 76.41 forceware drivers, nforce 5.10 mobo drivers
80GB IDE Maxtor HD
Lite-on DVD/CD RW
