imported_SpiderJohn
First, a little background info.
My computer is an off the shelf HP that is about 3 years old. (I am in the process of shopping to build a new one.) In the mean time, about 1 month ago, I tried to boot up and got the dreaded "Operating System not found" message.
This has happened to me on other computers and I assumed a HD failure. At the time, I was running a 40gb hd with operating system and other programs and a Maxtor 60gb for storage and photography programs.
Luckily, I had a spare 20gb HD, so, I replaced the "bad" hd with the 20gb, formatted and loaded my OS onto the 20 gig drive. System worked great! Went to work on some photos.....no 60gig drive listed in my computer (this was working before.)
Figured I must have pulled a cable loose while replacing the other drive, sure enough, my ribbon cable was unplugged. Plugged it in, powered up and get a message that windows had determined that a drive failure was imminent, back up all data. System would not boot any further.
Unplug the 60 gig drive, system works fine (although with much less hd space than I want).
I have tried playing with the jumper on the hd but got nowhere.
Anyone have any thoughts or suggestions?
Thought of buying a new hd that I will use in the new system; however, if my current box is screwing up my hard drives, I don't want to take that chance.
sj
sj
