fastamdman
Hey guys I have a hard drive that I need help with. Ok so I tried to install windows 7 on the hard drive and it kept saying "failed to create partition" and it wouldn't let me create a new partition, delete the partition nothing.
I put the hard drive into another system and it's showing up as unallocated space.
I need some way to create a partition on the drive, then delete it completely so I can install windows 7.
I tried to install windows xp, and the same thing happened.
Please help as I need to fix this issue ASAP.
Edit: When I open up disk management in windows 7 it pops up with disk 2 *aka the one that isn't working* and says.
You must initialize a disk before logical disk manager can access it.
Select disk 2
Use the following partition style for the selected disk
MBR
or
GPT
I have tried BOTH and neither work, it just says "Incorrect Function"
So as of now I am left with disk manager stating that disk 2 is not initialized and i have 149.01gb unallocated. Really need to get this drive working, brawr
Select disk 2
MBR
or
GPT
