Originally posted by: JackBurton
Originally posted by: DaveSimmons
You can also search, it's been discussed here fairly often.
Note that someone here fried a second hard drive trying a recovery when they placed the frozen drive above it in their drive cage. Apparently a little moisture dripped down and zap!
Uhh, yeah, that was me. I no likey freezer trick. It almost cost me another HD. :| I would NEVER recommend this "trick" to anyone. But if you want to try it, knock yourself out.
p.s. The frozen drive was not mounted above the other drive. It was actually sitting outside the case (door open). The problem was, it was on the same power chain as the main drive. I think the condensation inside the power connector on the frozen drive might have shorted the drive connected to it.
Not good.
