I'm formatting someone's computer and its freezing at 40%. I've tried using XP and 98 hoping it will make a difference. I've also tried quick and full formats - to no avail.
Anyone got any ideas?
It's possible the HDD may be bad. Go to the website of the HDD manufacturer and download their HDD diagnostic tools. Run them to see if the HDD has failed in some way. You can also generally zero-fill or "low-level format" a drive, which will reset the drive to the way it looked when the it came from the manufacturer.
