- Aug 13, 2010
- 5
- 0
- 0
I'm having problems with Windows failing or HDDs failing. Been going on for awhile. Started with bsod crashes that ended up screwing up Windows XP. New install wouldn't take. Finally, Windows wouldn't even finish install w/o crashing. Purchased new drive, installed Windows, everything fine until SP2 was installed, then PTTHHT. Ended up killing drive (bios wouldn't even see it). purshased new hdd and sent bad drive back to Seagate (they replaced, giving me 2 drives now). Still had problems, and posting to a different forum said could be psu. Got a better one from newegg), but that didn't help. Still lost windows after updates. so tried Windows 7 (partly in the hopes it was a driver issue, partly because I've been upgrading since Windows 3, and the #$%^#$@#$s want every version verified). Seemed to fix it (I don't know why) for a year now, until we lost power (i do have a surge suppressor), so I dont' think that did it, just improper shut down. Windows came up with it's handy "fix Windows or reboot" screen. It found errors and rand chkdsk, which took all night, but on restart Windows was still gone. Ended up having to clean install (format included) to get Windows back, but lost it again on second restart from updates. Reinstalled, then checked My Computer, which said only one drive was there, even though there were two. Reboot, check bios and saw both, but Windows still didn't see. Reboot again, remove one drive(they were identical, so couldn't be sure which had windows so picked the closest, lol)...no boot disk error. Swapped drives and got Windows couldn't start, try fixing Windows screen, which wouldnt fix
Windows. Sigh....Back to reinstall AGAIN.
So, there's the long story. So, I've checked to make sure all wires and SATA cables are properly seated. I've gotten a new PSU, but still have problems. Can it be the motherboard? Specs are below:
MSI K9A2 Platinum AM2+/AM2 AMD 790FX ATX AMD Motherboard
AMD Phenom 9850 BLACK EDITION 2.5GHz Socket AM2+ 125W Quad-Core Processor HD985ZXAGHBOX
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2P10664GK
EVGA 512-P3-N975-AR GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
NZXT Guardian 921 CS-NT-GD921-B Black Steel ATX Mid Tower Computer Case
Finally, the hard drives: Seagate® Barracuda® 3.5" SATA/300 Internal Hard Drive
Windows 7
What options are there???? Can't be hdds, that many bads in a row isn't possible. problem persisted through new power supply. For some odd reason win7 held it off until power outtage.
Hellllllppppp!!!!!
Windows 7
Hellllllppppp!!!!!
