Hard Drive Error - Trying to diagnose
brianblair
56
The hard drive in my brother's computer started acting funny...he was getting sporadic reboots and then system files were missing upon reboot. Finally he kept getting a BSOD and could never recover from it. I replaced the drive and got his computer running again.
I put the troubelsome hard drive into a USB enclosure thinking I could run chkdsk on it and possibly pull his data off of it. When I plug the drive in to a computer running Windows XP and turn the drive on, it whirrs for about 10 seconds, and the computer then reboots itself.
I'm looking for a way to diagnose this drive but when I can't even access it when it is plugged in, how the heck can I do this?
Any help would be greatly appreciated as this is something I have never encountered before.
EDIT:::::
The drive is a Hitachi Deskstar 500 GB Model HDS725050KLA360 Mfg'd in June 2005
It does not have any jumpers so I can't set it to slave.
Mondoman
356
Sounds like there may be a hardware failure in the drive's controller board, perhaps leading to unusual voltages on one or more of its interface pins. I certainly wouldn't plug it into any equipment that I didn't want to have fried. If you really want to recover data, you'll probably have to send it to a specialist company. If it really is just a controller board issue (rather than physical drive issue), they may be able to recover all the data fairly straightforwardly by attaching a new controller card.
brianblair
56
**UPDATE**
I took the drive to my local computer shop. They were able to retrieve the data using some sort of data recovery software to make a bit by bit copy of the drive. The bad drive has been junked.
