There are two drives on this system. I query the S.M.A.R.T. data of the drives using
HD-Inspector, Lavalys Everest and SpeedFan.
Question 1
The first drive is a Quantum fireball AS, based on the SMART data the only problem I see is the UltraATA CRC Error rate at value=1, worst=1.
-->Is this possibly a cabling issue jacking the error rate? (I am using the CoolerMaster round cables) and I see the grounding wire is loose. Is this the culprint, or is the drive going bad ?
Question 2
The second drive is Raptor WD740GB.
SMART, reports a spinup time value at 63. All other values are spotless, perfect (not a hitch anywhere). This drive has been on 24/7 since Jun10 2004. This is 12000 hours while the MTBF is 1.2 million hours.
-->Is this drive really wearing down ? I suspect, that there must be some friction build-up for it to have slow spinup. Is the temperature too low and thus the liquid bearings too viscus during startup ?
Is this drive wearing out sooner than expected ?
Question 1
Question 2
