DougK62
I'm working on a computer for a friend. He says it just out-of-the-blue would not start up and would hang when he started to run scandisk. I noticed that the header which the HSF was plugged into had burnt out. The fan was not on, so I figured that it was a heat related problem. I decide to just wipe the drive clean and try to start over. I FDISK it and all seems fine. I try to format it and it hangs - saying that it is trying to recover an area of the hard drive. Are there any other utils i could use to try to format this drive? If I am able to install on the drive again, is it now destined to take a poop on me in the future?
The computer is a K6-2 500 and the HDD is a 10GB Maxtor. Please give some input besides "just go buy a new one". We are on a very tight budget 🙂
Doug
Doug
