Hard drive damaged?
wseyller
824
This computer was left on over night. Next morning the computer was off. Bios does not detect the harddrive, so I get a disk boot failure. I took the side panel off switch around cables and ide channel and jumpers and that sort to get it to work, but no luck. I did hear what seems to be some unusual noise coming from the harddrive.
Anyone think its possible I could recover some documents.
wseyller
824
The bios only shows the cdr drive.
the data isn't that important for expensive recovery. It is only a few days of work.
Data backups were not currently in place. This computer was a couple years old, but was just place in an office a few days ago. Backups are done on all computers, but it wasn't implemented on this one yet.
powerMarkymark
2,164
Then just RMA the drive if possible.
wseyller
824
Cost is not a concern to me. I just want to know if any of you guys think there was any chance of data recovery. I was wondering if any of you had a cool trick that could use to get the data. If I could spend 2 hours to get 3 or 4 days worth of documents back it would save me a little time.
farscape
327
Pull the drive, insert in anti-static bag, put in freeze overnight, reinsert in another computer as a slave drive, boot system and see if you can read it. If good, get as much off it that you can. Freezer trick has worked for me a number of times in trying to recover data.
Jeff7
41,596
20
Was this the system in your sig? If not, what are the brand and model of the dead drive?
wseyller
824
It's not the one in my sig.
Seagate model ST340015A
timxpx
237
Originally posted by: funggorgor
find data recovery company to help you
I don't need the data enough to play a high price for expert data recovery.
have i heard right that professional data recovery costs in the thousands?
