hey,
whenever i open any applications,unrar,unzip,open folders, or soemthing like that, my hard drive is always making clicking sounds...is that bad and means that it will die soon?
thanks
A constant, timed clicking sound indicates a drive servo going bad. If the sound is sporadic and random, it may be normal depending on the brand of the drive. If this is something you have just recently noticed, it most likely means the drive is on it's way out.
I'd strongly suggest you first back up your important data files.
Then do a low level scan and let it run overnight.
Back up your files. Back up your files. Back up your files.
yeah the clicking sounds are occuring a lot more whenever i use the hard drive..like when i search for files and stuff. i am really concerned that it is broken..and in addition to that..my computer has slowed down by a lot.
yep had the same thing happen to me last fall.My Maxtor 10gb started making this horrible clicking sound...it couldnt get thru a scandisk...it was awful to listen to.
Get that RMA info ready man...that suckers is on its way out.
There is no scandisk in Windows 2000. You can run Checkdisk. Go to Start | Run and type "chkdsk /f" (without quotes). Click ok, it will prompt you to reboot. Let it reboot and run checkdisk. It should notify you of impending bad sectors.
If you formatted in Fat 32, another option is to make a Win98 bootup floppy disk (or go to bootdisk.com and download one), boot from it, and run scandisk in DOS mode.
usually when i hear a clicking drive its cause someone in the office can't boot up, and they get me to look at it. so i would say this is dead like everyone else, wonder how long it will take to die.
The drive could be good for months weeks or days depending on how bad the problem is. I had a co-worker with a bad laptop drive and he wouldn't do anything to replace it for 6 months and it was still running.
If your drive is going bad then you might be having seek time trouble which would explain the "slowdown" that you are observing.
As others have indicated, back your data up, buy a new drive and get ready to restore your system. Or buy a program like ghost or driveimage that would allow you to put the new drive in and direct copy your old drive to the new one. Just be warned that if you DO have corrupt data it might get copied to the new drive.
i would go get an rma ready...maxtor's rmas last 90 days...i had that problem...thinking it was a 60mm fan inside just rattling my cheap ass case...but nope...a month later my system would lock and my mobo would not even recognize it...it let me sneak in a couple of times...so i did a backup...then i formatted it just in case some mofo got me a virus...but it would just keep on dying after it tries to load windows. i have an rma on the way...maybe it'll take around a week more.
nooo nooo noo... if the heads were "bouncing" off the platters then your drive would be dead. It's more likely a servo or the bearing going out.
