Hard drive connection
willslick
4
Hello I have received most of the parts for my new build. I am waiting for the P.S. & tuner card. here are the components i selected.
Matt's Super Multi media / Gaming P.C. - Model # MWF2-07 Extreme
E4300-Processor Running at 400 MHz system bus ? (3.6ghz CPU)? 117.00
Gigabyte GA-965P-DS3 Mother board ? 116.00
Memory ? 2 x 1GIG. Patriot Extreme PC2- 6400 126.00
Windows Vista 190.00
Altec Lansing Speaker system 49.00
Logitech Cordless desk top key board / mouse ? 30.00
Ultra chill tech Thermo electric cooler ? 150.00
Video card GV-NX88S320H-B-RH ? 300.00
WD raptor Hard drive 10,00 RPM 74gig ? 140.00
Hard drive (2) WD SATA 500 gig 7200 RPM ? 240.00
DVD burner AD-7170s-ob ? 32.00
Floppy drive /card reader SIIG U2CRD RDR+FDD JU-91RW12-S4 RTL -39.00
Power supply PCPWR&COOL|SILENCER750 4-COPPER ? 199.00
Case Antec 900 ? 130.00
Monitor ? SCEPTRE X22WG-1080p ? 250.00
Tuner card ? T.V. Wonder 650 ? 97.0
CPU THERMPASTE ARCTIC SILVER5- 6.00
1394 Card 15.00
I want to set up the two 500gig drives in a raid 0 this build is a P.C. for my son age 13. I want it to be a learning experience for him and me. So more for the use of the technology than for performance i want to use the raid. This is how I plan on hooking up the drives The two 500gig drives in raid0 on the Intel sata ports. & the 74gig raptor & the dvd drive on the gigabyte ports. I will be using the raptor as a system drive. Will this configuration work? Any tips for a dad who is beginning to feel like he bit off more than he can chew? Thank guys for any advice or tips you can offer me. I really want this to work. By the way like i said all the parts are either on there way or already received so thats what i will be using.
Heidfirst
2,015
Originally posted by: willslickThis is how I plan on hooking up the drives The two 500gig drives in raid0 on the Intel sata ports. & the 74gig raptor & the dvd drive on the gigabyte ports. I will be using the raptor as a system drive. Will this configuration work?
No, the DS3 doesn't have Intel RAID.
You could run RAID on the Gigabyte (JMicron) controller though.
tungtung
194
Personally I would advise you NOT to set those two 500 gig drives in RAID 0.
You're just asking for more trouble than what it's worth.
The performance gain of RAID 0 is totally exaggerated compared to the risk of having drive failure on one of those drives.
As for configuration, put all drives on the intel SATA ports, and as you planned put the OS and programs on the Raptor.
Use 1 of the 500 gig drive as data storage, and the other as backup (if possible).
willslick
4
Thanks for the info. I still think its kind of cool to click on your hard drive property's & see a terabyte of available space
