- Jun 20, 2001
- 1,209
- 0
- 76
Ok, I'm really frustrated with this because I've been working on it for like a week now...I should've asked you all sooner for help.
I have this old Pentium 200 that I'm giving to someone. It had an old 3.2 gig HD. Before I gave it away I wanted to give them a decent HD, so I bought a 30.7gig IBM Deskstar 307030 from a fellow ATer. The HD is fine from what I can tell.
Now the problem... The Pentium computer wont fully recognize it as a 30gig HD. The most it will give me is 8gigs. I reformatted it when I first got it to clean it out so I could clean install Win98SE. I try and install Win98SE and it says that there's something wrong with the file system and it cant install the OS.
So I goto fdisk and it says size: 29K megabytes (basically 30gigs), but then it says file system: unknown (instead of the FAT32 I know I formatted it to). Also the max it will let me make the primary partition or total of any partitions is 8gigs.
I finally accepted it as 8gigs so I could install the OS and then install Partition Magic to see if it could change anything. PMagic says it's only an 8gig HD.
I put the HD in my Dell 4550 as a slave and run my PMagic...and it says 8gig partition, 22gigs unallocated (so it sees the full 30 gigs). I don't know why the other computer just wont accept it as a 30gig HD.
I went to the Abit site this morning and downloaded the latest BIOS and flashed the BIOS. I'm truly lost. I just want to be rid of this comp already...why wont it work...please some help...
Computer Info:
Processor: Pentium 200
BIOS: Award 4.51PG
Motherboard: AB-PR5
Chipset: Intel Triton VX Chipset
Hard Drive: IBM Deskstar 307030
If there's anything you need to know, just ask. Thanx in advance for any help.
Computer Info:
BIOS: Award 4.51PG
Motherboard: AB-PR5
