Hard Drive Caddy Reliability?
rcrickmay
I am having a problem consistently maintaining access to my hard drive within an HD Caddy.
• I just installed my new hard drive caddy to replace my cd/dvd rom drive.
• The Caddy is, DBPOWER SATA 2.5" / 9.5mm 2nd Hard Disk Drive Caddy Adapter.
• I installed the OLD HDD into the caddy (Seagate ST500LT012-1DG142).
• The OLD HDD was the original HD that the laptop came with.
• I replaced the OLD HDD with a KINGSTON SV300S37/A240G SSD.
• This SSD works without any issue.
• The old HDD worked without any issue.
• I plugged the old HDD into my desktop to test it out, and it works without issue (files can be transferred to and from it; it can be formatted (Quick and Normal); and partitions can be managed).
• When I put the OLD HDD into the caddy and boot up the laptop—no problems.
• When I try to format the OLD HDD in the laptop, it always fails before the format can finish.
• When I successfully format the OLD HDD in my desktop PC, and migrate it over to my Laptop, I cannot transfer files to it on my laptop, or create new folders, and etc.
• Now for a miracle.
• *Voodoo/Miracle* The OLD HDD works perfectly fine for a day or two in my laptop within the HD CADDY.
• Now it doesn’t work.
• When it doesn’t work the error I get when transferring files is, “Error 0x8007045D: the request could not be performed because of an I/O device error”
• I’m guessing it’s going to work on and off forever at this rate, but I don’t know why.
• It’s works today now.
• When the HDD is accessable within the caddy, the seek times are "exaggerated" to say the least.
Thank you.
HARDWARE LEGEND:
Old HDD: Seagate ST500LT012-1DG142
New SSD: KINGSTON SV300S37/A240G SSD
HD Caddy: DBPOWER SATA 2.5" / 9.5mm 2nd Hard Disk Drive Caddy Adapter
Laptop: Acer Aspire E15 Touch (E5-571P-59QA)
Quad5Ny
135
I'm assuming its a connection/interference problem, I would pick up a new adapter (from a different company).
Post your SMART log here, you can use the
Code:
 tag.  If there are a bunch of device-to-host or host-to-device errors, its almost definitely a connection problem.
[LIST=1]
[*]Download [URL]http://sourceforge.net/projects/smartmontools/files/smartmontools/6.3/smartmontools-6.3-1.win32-setup.exe/download[/URL]
[*]Extract with 7zip
[*]Keep smartctl.exe, Delete the rest
[*]Open a Elevated (Administrator) Command Prompt
[*]Run: [CODE]smartctl /dev/sda -a -x > \Users\Public\Desktop\SMART_Dump.txt
[/LIST]
Note: Your drive might be /dev/sdb instead of /dev/sda. Paste whichever one is the drive in question here.
rcrickmay
smartctl 6.3 2014-07-26 r3976 [x86_64-w64-mingw32-win8.1] (sf-6.3-1)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: SandForce Driven SSDs
Device Model: KINGSTON SV300S37A240G
Serial Number: 50026B724B0485EC
LU WWN Device Id: 5 0026b7 24b0485ec
Firmware Version: 580ABBF0
User Capacity: 240,057,409,536 bytes [240 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 03 09:51:36 2015 PST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Unavailable
Write cache is: Enabled
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x7d) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x0025) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate -O--CK 120 120 050 - 0/0
5 Retired_Block_Count PO--CK 100 100 003 - 0
9 Power_On_Hours_and_Msec -O--CK 100 100 000 - 118h+25m+51.160s
12 Power_Cycle_Count -O--CK 100 100 000 - 131
171 Program_Fail_Count -O-R-- 100 100 000 - 0
172 Erase_Fail_Count -O--CK 100 100 000 - 0
174 Unexpect_Power_Loss_Ct ----CK 000 000 000 - 11
177 Wear_Range_Delta ------ 000 000 000 - 0
181 Program_Fail_Count -O-R-- 100 100 000 - 0
182 Erase_Fail_Count -O--CK 100 100 000 - 0
187 Reported_Uncorrect -O--C- 100 100 000 - 0
189 Airflow_Temperature_Cel ------ 022 035 000 - 22 (Min/Max 15/35)
194 Temperature_Celsius -O---K 022 035 000 - 22 (Min/Max 15/35)
195 ECC_Uncorr_Error_Count --SRC- 120 120 000 - 0/0
196 Reallocated_Event_Count PO--CK 100 100 003 - 0
201 Unc_Soft_Read_Err_Rate --SRC- 120 120 000 - 0/0
204 Soft_ECC_Correct_Rate --SRC- 120 120 000 - 0/0
230 Life_Curve_Status PO--C- 100 100 000 - 100
231 SSD_Life_Left PO--C- 100 100 010 - 0
233 SandForce_Internal -O--CK 000 000 000 - 286
234 SandForce_Internal -O--CK 000 000 000 - 291
241 Lifetime_Writes_GiB -O--CK 000 000 000 - 291
242 Lifetime_Reads_GiB -O--CK 000 000 000 - 308
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x04 GPL,SL R/O 16 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xb7 GPL,SL VS 16 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log (GP Log 0x03) not supported
SMART Error Log not supported
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Self-test log structure revision number 1
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 0 (0x0000)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 21 Celsius
Power Cycle Min/Max Temperature: 15/35 Celsius
Lifetime Min/Max Temperature: 15/71 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 10 minutes
Min/Max recommended Temperature: 0/70 Celsius
Min/Max Temperature Limit: 0/85 Celsius
Temperature History Size (Index): 478 (353)
Index Estimated Time Temperature Celsius
354 2015-01-31 02:20 27 ********
355 2015-01-31 02:30 28 *********
356 2015-01-31 02:40 29 **********
357 2015-01-31 02:50 30 ***********
... ..( 3 skipped). .. ***********
361 2015-01-31 03:30 30 ***********
362 2015-01-31 03:40 31 ************
... ..( 2 skipped). .. ************
365 2015-01-31 04:10 31 ************
366 2015-01-31 04:20 26 *******
367 2015-01-31 04:30 25 ******
368 2015-01-31 04:40 ? -
369 2015-01-31 04:50 24 *****
370 2015-01-31 05:00 25 ******
371 2015-01-31 05:10 27 ********
372 2015-01-31 05:20 27 ********
373 2015-01-31 05:30 29 **********
374 2015-01-31 05:40 29 **********
375 2015-01-31 05:50 28 *********
376 2015-01-31 06:00 ? -
377 2015-01-31 06:10 27 ********
378 2015-01-31 06:20 28 *********
379 2015-01-31 06:30 29 **********
380 2015-01-31 06:40 28 *********
381 2015-01-31 06:50 29 **********
382 2015-01-31 07:00 ? -
383 2015-01-31 07:10 ? -
384 2015-01-31 07:20 24 *****
385 2015-01-31 07:30 24 *****
386 2015-01-31 07:40 24 *****
387 2015-01-31 07:50 25 ******
388 2015-01-31 08:00 ? -
389 2015-01-31 08:10 25 ******
390 2015-01-31 08:20 25 ******
391 2015-01-31 08:30 26 *******
392 2015-01-31 08:40 29 **********
393 2015-01-31 08:50 30 ***********
394 2015-01-31 09:00 ? -
395 2015-01-31 09:10 25 ******
396 2015-01-31 09:20 25 ******
397 2015-01-31 09:30 26 *******
398 2015-01-31 09:40 ? -
399 2015-01-31 09:50 ? -
400 2015-01-31 10:00 ? -
401 2015-01-31 10:10 23 ****
402 2015-01-31 10:20 ? -
403 2015-01-31 10:30 25 ******
404 2015-01-31 10:40 27 ********
405 2015-01-31 10:50 28 *********
406 2015-01-31 11:00 28 *********
407 2015-01-31 11:10 29 **********
408 2015-01-31 11:20 30 ***********
409 2015-01-31 11:30 30 ***********
410 2015-01-31 11:40 31 ************
411 2015-01-31 11:50 31 ************
412 2015-01-31 12:00 31 ************
413 2015-01-31 12:10 32 *************
414 2015-01-31 12:20 31 ************
415 2015-01-31 12:30 30 ***********
416 2015-01-31 12:40 29 **********
... ..( 16 skipped). .. **********
433 2015-01-31 15:30 29 **********
434 2015-01-31 15:40 28 *********
435 2015-01-31 15:50 27 ********
436 2015-01-31 16:00 26 *******
437 2015-01-31 16:10 ? -
438 2015-01-31 16:20 22 ***
439 2015-01-31 16:30 23 ****
440 2015-01-31 16:40 ? -
441 2015-01-31 16:50 21 **
442 2015-01-31 17:00 25 ******
443 2015-01-31 17:10 28 *********
446 2015-01-31 17:40 28 *********
447 2015-01-31 17:50 29 **********
... ..( 5 skipped). .. **********
453 2015-01-31 18:50 29 **********
454 2015-01-31 19:00 ? -
455 2015-01-31 19:10 27 ********
456 2015-01-31 19:20 27 ********
457 2015-01-31 19:30 28 *********
458 2015-01-31 19:40 28 *********
459 2015-01-31 19:50 27 ********
... ..( 4 skipped). .. ********
464 2015-01-31 20:40 27 ********
465 2015-01-31 20:50 28 *********
466 2015-01-31 21:00 27 ********
... ..( 7 skipped). .. ********
474 2015-01-31 22:20 27 ********
475 2015-01-31 22:30 28 *********
476 2015-01-31 22:40 28 *********
477 2015-01-31 22:50 ? -
0 2015-01-31 23:00 20 *
1 2015-01-31 23:10 22 ***
2 2015-01-31 23:20 23 ****
3 2015-01-31 23:30 23 ****
4 2015-01-31 23:40 24 *****
7 2015-02-01 00:10 24 *****
8 2015-02-01 00:20 ? -
9 2015-02-01 00:30 24 *****
13 2015-02-01 01:10 24 *****
14 2015-02-01 01:20 ? -
15 2015-02-01 01:30 23 ****
16 2015-02-01 01:40 24 *****
17 2015-02-01 01:50 25 ******
18 2015-02-01 02:00 26 *******
19 2015-02-01 02:10 27 ********
20 2015-02-01 02:20 27 ********
21 2015-02-01 02:30 ? -
22 2015-02-01 02:40 21 **
23 2015-02-01 02:50 24 *****
24 2015-02-01 03:00 26 *******
25 2015-02-01 03:10 25 ******
26 2015-02-01 03:20 26 *******
32 2015-02-01 04:20 26 *******
33 2015-02-01 04:30 27 ********
... ..( 8 skipped). .. ********
42 2015-02-01 06:00 27 ********
43 2015-02-01 06:10 28 *********
44 2015-02-01 06:20 29 **********
48 2015-02-01 07:00 29 **********
49 2015-02-01 07:10 30 ***********
50 2015-02-01 07:20 29 **********
51 2015-02-01 07:30 30 ***********
52 2015-02-01 07:40 30 ***********
53 2015-02-01 07:50 29 **********
... ..( 4 skipped). .. **********
58 2015-02-01 08:40 29 **********
59 2015-02-01 08:50 28 *********
60 2015-02-01 09:00 28 *********
61 2015-02-01 09:10 27 ********
66 2015-02-01 10:00 27 ********
67 2015-02-01 10:10 ? -
68 2015-02-01 10:20 22 ***
69 2015-02-01 10:30 23 ****
70 2015-02-01 10:40 24 *****
71 2015-02-01 10:50 ? -
72 2015-02-01 11:00 23 ****
73 2015-02-01 11:10 24 *****
74 2015-02-01 11:20 24 *****
75 2015-02-01 11:30 ? -
76 2015-02-01 11:40 22 ***
77 2015-02-01 11:50 23 ****
78 2015-02-01 12:00 24 *****
79 2015-02-01 12:10 ? -
80 2015-02-01 12:20 24 *****
81 2015-02-01 12:30 24 *****
82 2015-02-01 12:40 ? -
83 2015-02-01 12:50 26 *******
84 2015-02-01 13:00 29 **********
85 2015-02-01 13:10 32 *************
86 2015-02-01 13:20 32 *************
87 2015-02-01 13:30 ? -
88 2015-02-01 13:40 ? -
89 2015-02-01 13:50 23 ****
90 2015-02-01 14:00 24 *****
91 2015-02-01 14:10 25 ******
92 2015-02-01 14:20 26 *******
93 2015-02-01 14:30 ? -
94 2015-02-01 14:40 23 ****
95 2015-02-01 14:50 26 *******
96 2015-02-01 15:00 27 ********
97 2015-02-01 15:10 28 *********
98 2015-02-01 15:20 28 *********
99 2015-02-01 15:30 28 *********
100 2015-02-01 15:40 29 **********
103 2015-02-01 16:10 29 **********
104 2015-02-01 16:20 28 *********
105 2015-02-01 16:30 ? -
106 2015-02-01 16:40 27 ********
107 2015-02-01 16:50 28 *********
108 2015-02-01 17:00 29 **********
111 2015-02-01 17:30 29 **********
112 2015-02-01 17:40 ? -
113 2015-02-01 17:50 25 ******
114 2015-02-01 18:00 26 *******
115 2015-02-01 18:10 26 *******
116 2015-02-01 18:20 ? -
117 2015-02-01 18:30 24 *****
118 2015-02-01 18:40 26 *******
119 2015-02-01 18:50 27 ********
120 2015-02-01 19:00 28 *********
121 2015-02-01 19:10 28 *********
122 2015-02-01 19:20 28 *********
123 2015-02-01 19:30 29 **********
124 2015-02-01 19:40 ? -
125 2015-02-01 19:50 27 ********
126 2015-02-01 20:00 28 *********
127 2015-02-01 20:10 28 *********
128 2015-02-01 20:20 29 **********
129 2015-02-01 20:30 29 **********
130 2015-02-01 20:40 30 ***********
131 2015-02-01 20:50 29 **********
132 2015-02-01 21:00 29 **********
133 2015-02-01 21:10 ? -
134 2015-02-01 21:20 24 *****
135 2015-02-01 21:30 24 *****
136 2015-02-01 21:40 25 ******
137 2015-02-01 21:50 25 ******
138 2015-02-01 22:00 ? -
139 2015-02-01 22:10 21 **
140 2015-02-01 22:20 24 *****
141 2015-02-01 22:30 26 *******
142 2015-02-01 22:40 26 *******
143 2015-02-01 22:50 27 ********
149 2015-02-01 23:50 27 ********
150 2015-02-02 00:00 ? -
151 2015-02-02 00:10 25 ******
152 2015-02-02 00:20 27 ********
153 2015-02-02 00:30 28 *********
154 2015-02-02 00:40 28 *********
155 2015-02-02 00:50 29 **********
159 2015-02-02 01:30 29 **********
160 2015-02-02 01:40 ? -
161 2015-02-02 01:50 27 ********
162 2015-02-02 02:00 28 *********
163 2015-02-02 02:10 28 *********
164 2015-02-02 02:20 30 ***********
165 2015-02-02 02:30 29 **********
166 2015-02-02 02:40 29 **********
167 2015-02-02 02:50 29 **********
168 2015-02-02 03:00 ? -
169 2015-02-02 03:10 25 ******
170 2015-02-02 03:20 27 ********
171 2015-02-02 03:30 28 *********
172 2015-02-02 03:40 28 *********
173 2015-02-02 03:50 29 **********
... ..( 9 skipped). .. **********
183 2015-02-02 05:30 29 **********
184 2015-02-02 05:40 ? -
185 2015-02-02 05:50 28 *********
186 2015-02-02 06:00 29 **********
187 2015-02-02 06:10 29 **********
188 2015-02-02 06:20 30 ***********
189 2015-02-02 06:30 30 ***********
190 2015-02-02 06:40 30 ***********
191 2015-02-02 06:50 ? -
192 2015-02-02 07:00 22 ***
193 2015-02-02 07:10 24 *****
194 2015-02-02 07:20 24 *****
195 2015-02-02 07:30 24 *****
196 2015-02-02 07:40 25 ******
197 2015-02-02 07:50 25 ******
198 2015-02-02 08:00 26 *******
199 2015-02-02 08:10 25 ******
200 2015-02-02 08:20 25 ******
201 2015-02-02 08:30 25 ******
202 2015-02-02 08:40 26 *******
203 2015-02-02 08:50 26 *******
204 2015-02-02 09:00 ? -
205 2015-02-02 09:10 24 *****
206 2015-02-02 09:20 25 ******
207 2015-02-02 09:30 25 ******
208 2015-02-02 09:40 ? -
209 2015-02-02 09:50 25 ******
210 2015-02-02 10:00 ? -
... ..( 2 skipped). .. -
213 2015-02-02 10:30 ? -
214 2015-02-02 10:40 22 ***
215 2015-02-02 10:50 24 *****
216 2015-02-02 11:00 25 ******
217 2015-02-02 11:10 25 ******
218 2015-02-02 11:20 26 *******
219 2015-02-02 11:30 26 *******
220 2015-02-02 11:40 26 *******
221 2015-02-02 11:50 27 ********
225 2015-02-02 12:30 27 ********
226 2015-02-02 12:40 28 *********
231 2015-02-02 13:30 28 *********
232 2015-02-02 13:40 29 **********
233 2015-02-02 13:50 30 ***********
234 2015-02-02 14:00 30 ***********
235 2015-02-02 14:10 31 ************
236 2015-02-02 14:20 31 ************
237 2015-02-02 14:30 31 ************
238 2015-02-02 14:40 30 ***********
239 2015-02-02 14:50 31 ************
240 2015-02-02 15:00 ? -
241 2015-02-02 15:10 21 **
242 2015-02-02 15:20 24 *****
243 2015-02-02 15:30 27 ********
244 2015-02-02 15:40 28 *********
245 2015-02-02 15:50 29 **********
248 2015-02-02 16:20 29 **********
249 2015-02-02 16:30 ? -
250 2015-02-02 16:40 19 -
251 2015-02-02 16:50 20 *
252 2015-02-02 17:00 21 **
253 2015-02-02 17:10 22 ***
254 2015-02-02 17:20 22 ***
255 2015-02-02 17:30 23 ****
256 2015-02-02 17:40 23 ****
257 2015-02-02 17:50 23 ****
258 2015-02-02 18:00 24 *****
259 2015-02-02 18:10 24 *****
260 2015-02-02 18:20 24 *****
261 2015-02-02 18:30 25 ******
262 2015-02-02 18:40 26 *******
263 2015-02-02 18:50 26 *******
264 2015-02-02 19:00 26 *******
265 2015-02-02 19:10 ? -
266 2015-02-02 19:20 26 *******
267 2015-02-02 19:30 27 ********
268 2015-02-02 19:40 ? -
269 2015-02-02 19:50 ? -
270 2015-02-02 20:00 20 *
271 2015-02-02 20:10 23 ****
272 2015-02-02 20:20 24 *****
273 2015-02-02 20:30 ? -
274 2015-02-02 20:40 26 *******
275 2015-02-02 20:50 27 ********
278 2015-02-02 21:20 27 ********
279 2015-02-02 21:30 ? -
280 2015-02-02 21:40 25 ******
281 2015-02-02 21:50 28 *********
282 2015-02-02 22:00 27 ********
283 2015-02-02 22:10 27 ********
284 2015-02-02 22:20 30 ***********
285 2015-02-02 22:30 29 **********
286 2015-02-02 22:40 30 ***********
287 2015-02-02 22:50 ? -
288 2015-02-02 23:00 22 ***
289 2015-02-02 23:10 24 *****
290 2015-02-02 23:20 25 ******
291 2015-02-02 23:30 26 *******
292 2015-02-02 23:40 ? -
293 2015-02-02 23:50 22 ***
294 2015-02-03 00:00 24 *****
295 2015-02-03 00:10 25 ******
296 2015-02-03 00:20 26 *******
297 2015-02-03 00:30 27 ********
298 2015-02-03 00:40 28 *********
299 2015-02-03 00:50 29 **********
304 2015-02-03 01:40 29 **********
305 2015-02-03 01:50 30 ***********
306 2015-02-03 02:00 31 ************
307 2015-02-03 02:10 30 ***********
308 2015-02-03 02:20 31 ************
309 2015-02-03 02:30 31 ************
310 2015-02-03 02:40 30 ***********
... ..( 9 skipped). .. ***********
320 2015-02-03 04:20 30 ***********
321 2015-02-03 04:30 ? -
322 2015-02-03 04:40 23 ****
323 2015-02-03 04:50 25 ******
324 2015-02-03 05:00 26 *******
325 2015-02-03 05:10 30 ***********
326 2015-02-03 05:20 32 *************
327 2015-02-03 05:30 32 *************
328 2015-02-03 05:40 33 **************
329 2015-02-03 05:50 32 *************
330 2015-02-03 06:00 30 ***********
331 2015-02-03 06:10 31 ************
332 2015-02-03 06:20 32 *************
333 2015-02-03 06:30 30 ***********
334 2015-02-03 06:40 29 **********
335 2015-02-03 06:50 28 *********
336 2015-02-03 07:00 ? -
337 2015-02-03 07:10 25 ******
338 2015-02-03 07:20 26 *******
339 2015-02-03 07:30 26 *******
340 2015-02-03 07:40 27 ********
341 2015-02-03 07:50 28 *********
345 2015-02-03 08:30 28 *********
346 2015-02-03 08:40 ? -
347 2015-02-03 08:50 27 ********
348 2015-02-03 09:00 29 **********
349 2015-02-03 09:10 30 ***********
352 2015-02-03 09:40 30 ***********
353 2015-02-03 09:50 ? -
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Description
1 ===== = = == General Statistics (rev 1) ==
1 0x008 4 131 Lifetime Power-On Resets
1 0x010 4 118 Power-on Hours
1 0x018 6 610768281 Logical Sectors Written
1 0x028 6 647554051 Logical Sectors Read
4 ===== = = == General Errors Statistics (rev 1) ==
4 0x008 4 0 Number of Reported Uncorrectable Errors
4 0x010 4 352 Resets Between Cmd Acceptance and Completion
5 ===== = = == Temperature Statistics (rev 1) ==
5 0x008 1 22 Current Temperature
5 0x010 1 27 Average Short Term Temperature
5 0x018 1 - Average Long Term Temperature
5 0x020 1 67 Highest Temperature
5 0x028 1 18 Lowest Temperature
5 0x030 1 31 Highest Average Short Term Temperature
5 0x038 1 26 Lowest Average Short Term Temperature
5 0x040 1 - Highest Average Long Term Temperature
5 0x048 1 - Lowest Average Long Term Temperature
5 0x050 4 0 Time in Over-Temperature
5 0x058 1 70 Specified Maximum Operating Temperature
5 0x060 4 0 Time in Under-Temperature
5 0x068 1 0 Specified Minimum Operating Temperature
6 ===== = = == Transport Statistics (rev 1) ==
6 0x008 4 0 Number of Hardware Resets
6 0x010 4 453 Number of ASR Events
6 0x018 4 358 Number of Interface CRC Errors
7 ===== = = == Solid State Device Statistics (rev 1) ==
7 0x008 1 0 Percentage Used Endurance Indicator
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 7 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 7 Device-to-host register FISes sent due to a COMRESET
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0010 2 0 R_ERR response for host-to-device data FIS, non-CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x0013 2 0 R_ERR response for host-to-device non-data FIS, non-CRC
0x0002 2 0 R_ERR response for data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
Feb 25, 2011
17,000
1,628
That's your SSD - you need the HD, probably "/dev/sdb."
But I'd just replace the caddy. They're not expensive, and it's obviously causing issues. I used one in my last laptop for several years with no hiccoughs. (I think it was even the same brand/model you have there.)
Defective stuff happens.
rcrickmay
I think I'll just have to replace then, I've spent more man hours on the caddy than the price of a new one. Analysis paralysis...
Thanks again!
Here's 'sdb' info;
Read Device Identity failed: Input/output error
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
