Hard Drive cable
scott408
I have a DMA 66 HD able that came with my Abit KT7-Raid motherboard. I just got a DMA 100 Hd. Can I use that same DMA 66 cable with the DMA 100 HD with the onboard DMA 100 controller? In others words, is DMA 66 cable the same as DMA 100? thanks
<< Yes they are the same. Both uses the 80 pin cable >>
uh, the first part is right, the second is not.
it's a 40 pin cable, with 80 wires. subtle difference. yeah, i know what you meant pillage, but just a correction.
