Hard Drive - Backup Failure (Data Recovery CRC Errors)
ramoar
Hello Anandtech,
I was hoping that you could help me out with a problem I am having backing up a hard drive. Here's the specifics:
>Sister's laptop crashed. She needs data backed up.
>Cannot enter Windows Vists, BSOD's. Safe Mode also crashes.
>I tried attaching it to an external SATA>USB connector to back it up. Connected it to my Windows 7 PC.
>Backup Drive is recognized, as is the HP Recovery Partition as G & H Drives respectively.
>Upon trying to access the drive it tells me that it needs to be formatted.
>Going into Computer Management tells me that the file system is RAW & it is 100% empty of data.
>Downloaded PCTools FileRecovery to see if it could see anything and it can pull the Recovery partition from HP but does not even see the G drive.
I am signed into my PC as an admin...any ideas?
Thanks in advance for your help.
Absolutely, it is looking like its toast. Could it be something with a corrupted partition or MBR? I'll check out that program. Thank You!
Quick update - Recuva can actually see the G drive. So that is a positive step.
It may just be corrupted. I would ask myself ... Would I trust it again with hard disk prices as low as they are?
I would install a new drive.
The drive is corrupted. Doing a deep scan to hopefully pull as much as possible off of it. Thanks again for the suggestion of Recuva.
