Ok, i didnt see any mention of this on the main faq threads, so here goes.
Ive got two pcs atm, both of which are giving me harddrive issues this past two weeks.
The first one
core2duo e8400
4 gigs ocz ddr2 800 (formerly 2 gigs)
evga 780i motherboard
pair of 7800 gtx in sli
wd raptor 74 gig (primary OS drive)
seagate barracuda 400 gig
audigy 4
winxp pro sp3
On this machine the raptor up and died out of the blue. Turned the machine off in the morning with everything fine, come home from work to a disk read error at bootup and a bricked pc. Whatever happened, it up and destroyed the partition and everything on it, as when i replaced it yesterday (with a 320 gig seagate barracuda) i plugged it in as a third drive hoping it was just the boot sector that was fubared and not everything, so that i could save some of my files, only to find it listed as 70 gigs roundabouts of raw unpartitioned space. Now my question is is this normal? What could cause a partition to just self destruct overnight like that, and not even with the machine turned on?
Also while on the topic of this pc, as i mentioned earlier when i replace the toasted drive , i also uppped the memory to 4 gigs from 2. Now i know i wont see all 4 gigs due to it being 32 bit xp, but shouldnt i see at least 3-3.5 gigs of it? Cause right now its only listing 2.5 gigs. I know the memory works as its all getting detected on bootup in the bios. Is there anything i can do?
Now on to the second pc.
core2duo e8400
8 gigs ocz ddr 2 800
evga 780i
pair of 8800gt in sli
wd raptorx 150 gig (primary os drive)
seagate barracuda 1tb
x-fi gamer
winxp 64 bit
With this machine a couple days ago i started getting "windows delayed write failure" errors referring to the secondary drive (the seagate), at which point the system would get incredibly unstable and require a hard boot to fix. Now i can still acess the files on the drive, and everything seems to work, although the transfer rate to and from that drive is flakey at best. Going anywheres from normal to dead stopped at random. The errors dont come up consistantly either. At times its happened right after bootup, other times its happened hours later. Any idea what could be causing this, and what i could do to fix it? Ie is it a physical drive problem, or just windows being stupid? I was just going to try and rma the drive (as the whole system is maybe 7 months old) but i cant get the damn seagate tools to run on the machine, it being 64bit.
Any help with these issues is greatly appreciated. I dont know where else to look.Thanks.
The first one
core2duo e8400
audigy 4
winxp pro sp3
core2duo e8400
evga 780i
x-fi gamer
winxp 64 bit
