rookie1010
I can not shut down my WD media centre 160 GB. there is this on/off switch in front which as the name suggests is used to turn on off the disk, only when i push it to turn it off, the blue LED light behind it blinks on and off couple of times, and then remains on.
i followed the sinstructions provided by western digital(safely removing references to USB in the system tray), and then turning it off, but that does not work either
